mbell666 wrote:generally the turbo's on pugs are quite good and last pretty well.
Are they?? Damn.... I'm on my 5th Turbo... lol - But this is a petrol ! !
Ok so mine is a mixture of being sold something that was never fitted and my right foot! ! !
Typically its irregular oil changes, and poor driving conditions.... thrash cold and no idle cool down time.. On the Pug's the tub's are low pressure so its not down to the pressure, most problems can be attributed to Oil and Coking... Seals typically fail as a result of coking on these low pressure units.
What happens depends on the failure....
1) Foreign Object - Compressor Wheel / Turbine Wheel can shatter and the debris can take out the cover and/or core
2) Coking - Bearings weld to the core and the shaft making it impossible to rotate
3) Seals blow - Exhaust and Compressor housings fill with oil and result in blue smoke
4) Oil contamination - Scoring to the shaft and bearings
5) Oil Starvation - blockage in feed pipe can cause bearings to run dry and 'burn in' the core, results in blue coloring of the shaft in places and eats into the core.
6) Thrust bearing / Plate wear due to excessive boost pressure's can result in 'in/out' shaft play
6) Worn bearings due to excessive boost pressure's and oil conditions can result in 'typical left/right' shaft play
Anything else you would like to know
