Adding injector cleaner via fuel filter housing?
Posted: Thu Sep 27, 2007 11:47 pm
by legoless
Hi
I am just about to do a fuel filter change on my 2.1 tdi, and was thinking about putting some forte injection cleaner directly into the filter housing when I pop the new one in.
Has anyone done this and if so how much should I add for a good clean of the injectors etc. I have put in slick 50 injection cleaner into the tank as per instructions every 3000 to 6000 miles since I got the car, but having read the forums about forte I decided to try some out and hence the query :)
Posted: Fri Sep 28, 2007 8:02 am
WOW, if your already putting cleaner in regularly you shouldn't need too much of the Forte.
I use Forte once a year! My garage pours it into the filter on other peoples cars but I put it in the tank to work over a few days.
In your case I would put 1/4 of a bottle in the housing and the rest in the tank. I don't like the idea of neat injector cleaner going through the pump I'm not sure how much of a lubricant it is.
See what the others think too.
Posted: Fri Sep 28, 2007 9:21 am
by darrenwall
i used to do this on my old 2.1TD regularly and never had any problem cos most injector cleaners contain kerosene which is a fuel similair to diesel ( i think :? ) . just give it a good rev to around 3500 rpm for a few seconds when you first start it to make sure that no air has chance to airlock the system :cheesy:
Posted: Fri Sep 28, 2007 5:54 pm
by legoless
Thanks for the info will have a go over the weekend
