Brake Problem??
Posted: Fri Sep 28, 2007 9:36 am
by GeordieBoy
Got a bit of a brake problem atm, sometimes when I press the brake it sometimes feels like the ABS is kicking in even tho I aint heavy braking, feel a bit of vibration thru the pedal. I have to really stamp on the brakes to stop otherwise they wont work. Brake pads are fine, only renewed a few mths ago, and discs appear ok aswell.
Posted: Fri Sep 28, 2007 9:48 am
Sounds like one of the ABS wheel sensors thinks a wheel is locking up and is activating the ABS pump.
The wheel sensors will need removing and inspecting/cleaning I would say.
How do you know that your glued-on sensor gear hasn't fallen off????
Posted: Fri Sep 28, 2007 12:25 pm
by GeordieBoy
Welton wrote:Sounds like one of the ABS wheel sensors thinks a wheel is locking up and is activating the ABS pump.
What glued on sensor? The ABS Ring is sound. :cheesy:
Posted: Fri Sep 28, 2007 9:33 pm
by jameslxdt
could be a warped brake disc, only way to check is with a DTi gauge
Posted: Sun Sep 30, 2007 7:12 am
by GeordieBoy
Faulty ABS Sensor we think, so gonna pull the ABS fuse until I can get it fixed next week.
