Page 1 of 4
The head is off.... almost
Posted: Sat Nov 10, 2007 5:41 pm
by jameslxdt
i finally made use of this weekend to start work on the new car, i started of last night welding up the exhaust downpipe, started the car, and found the rearbox to centre section had rotted right at the flange, in the exact same place where wellys one went, so after much more welding and setting fire to myself and covering it in gungum, its silent again, though after running the engine for a while i noticed the water pump was leaking like a lot :lol: so i thought fook it, and spent the afternoon taking the head off, its sort of almost off, the head is partially clear of the block, but i forgot to unbolt the turbo oil supply, and i noticed that the union is fookin great big 20mm-ish allen bolt, so by this time it was 5pm, i was coverd in oil, anti-freeze, i could only see out of one eye so i gave in, i managed to pull the gasket out, but at this stage i cant see where its gone, thats a job for the morning along with a trip to halfrauds to get the right size socket and take the head out and get it sent away for skimming
then it'll be a case of getting an MOT and roof rail then roll on happy D9 motoring 8)
i hope :lol:
Re: The head is off.... almost
Posted: Sat Nov 10, 2007 5:53 pm
Off with her head!
jameslxdt wrote:...i was coverd in oil, anti-freeze, i could only see out of one eye so i gave in
Ah, I remember the days of my youth... The last head I had off had 6 pots, 2 cams and 24 valves and, despite being alloy,weighed a farking ton. Never again!
jameslxdt wrote:...setting fire to myself
I done that too! I was under a mate's car wearing goggles and lying on a lump of foam rubber, I didn't notice but my mate walked past and did a double-take "Steve! You're on fire!!!"
[James's mum]I hope you're wearing gloves young man[/James's mum]
Posted: Sat Nov 10, 2007 6:49 pm
by TooT
It will be worth it in the end james, coz D9 motoring is de best :lol:
Posted: Sat Nov 10, 2007 7:06 pm
by jameslxdt
we shall see :lol:
Posted: Sun Nov 11, 2007 9:54 am
by V6Exec
steve_earwig wrote:The last head I had off had 6 pots, 2 cams and 24 valves and, despite being alloy,weighed a farking ton.
How about:- 6 pots, 0 cams, 6 valves, Inclined mating surface
Posted: Sun Nov 11, 2007 10:23 am
6 pots with 6 valves, strange engine! :cheesy:
Posted: Sun Nov 11, 2007 12:06 pm
Keep up the good work fella! sounds a right pig of a job :(
Posted: Sun Nov 11, 2007 12:40 pm
by V6Exec
steve_earwig wrote:6 pots with 6 valves, strange engine! :cheesy:
It is a Rolls Royce design, the IOE engine.
Posted: Sun Nov 11, 2007 1:22 pm
by mbell666
jameslxdt wrote:.... started the car, and found the rearbox to centre section had rotted right at the flange, in the exact same place where wellys one went
I've had that two, i can't weld :( so i just got a new back box.
Sounds a fun job not!
Posted: Sun Nov 11, 2007 6:56 pm
by jameslxdt
yep it was a pig to get out, but i got it done this morning :cheesy:
it nearly ended in disaster, as i went to put the head on the workbench, i tripped and threw it :shock:
first it bouced off my leg, ouch, :cry: then hit the floor, thankfully only one corner of the gasket face was damaged, the inlet manifold cracked and the thermostat housing smashed, thankfully there all still usable
ive got the gasket and bolts and few other bits on order so ill have next weekend to put it all back together 8)
Posted: Sun Nov 11, 2007 9:35 pm
by TooT
:shock: Jeez just look at that mass of wires, pipes, and sh*t everywhere. Im glad you know what your doin there.
Sounds as tho its gonner be better than new when finished. Nice one 8)
Posted: Sun Nov 11, 2007 9:38 pm
by jameslxdt
TooT wrote: Im glad you know what your doin there
or you hope i do :lol:
Posted: Sun Nov 11, 2007 11:23 pm
by V6Exec
This is the acid test, if James does not get it back together will we ever believe him again??? :lol: :lol: :lol:
Posted: Mon Nov 12, 2007 10:57 am
If you could see me now James I am taking my hat off to you, and your lucky because I always wear a hat on a Monday :lol:
What a horrible job, I mean, just how do you get to some of the bolts around the exhaust manifold etc?
That would be the kind of job that (even if I could strip it down to that level) I would just never put it all back again :cry:
Look forward to the next episode then 8)
Posted: Mon Nov 12, 2007 3:13 pm
by puggy
Excellent job that man james !! if i ever need that kind of work doing i know
who to take it to (mates rates of course :P :P )
