Page 1 of 2
Right engine mount
Posted: Thu Nov 15, 2007 8:52 pm
by mjb
Dammit I'm pissed off
Paid £90 for a new right (top) engine mount bracket from the dealers because the bush was vibrating like mad, did 12 miles AND fitted it in my lunch break today, and guess what? It's STILL vibrating like mad!
At least it's improved things a little. If I'm careful and very gentle pulling off I don't get the nasty metal-on-metal vibrating sound, but ARGH £90! I had a look and the little bush in the rear bracket is cracked to hell but not moving much and the lampshade shaped mount doesn't look damaged, but is moving a fair bit.
I think I'll spend the £20 to replace the lampshade shaped part... The question is how do you remove/replace it? I can't tell how it's fixed to the body...
Also how tight should the joints through the bushes be? Should they be tight enough to restrict rotational movement or loose enough to let the joint bend?
Re: Right engine mount
Posted: Sat Nov 17, 2007 7:00 pm
by jameslxdt
i had the same issue and changed the wrong mounting
this is the bugger that causes the vibration
Posted: Sun Nov 18, 2007 11:22 pm
by mjb
jameslxdt wrote:i had the same issue and changed the wrong mounting
Yeah my one of those is bad too, but last time I looked wasn't quite as bad as that one.
Part #183946 £27.95 inc vat according to the servicebox website. I was expecting it to be more expensive than that. Think I'll be on the blower to the stealers first thing in the morning!
Posted: Mon Nov 19, 2007 7:19 pm
by jameslxdt
yeah i think mine cost arround £20, it looked ok till i took it out, and its a bugger to get out
Posted: Mon Nov 19, 2007 8:37 pm
by mjb
Piece of cake to get out... I've pulled the whole bracket out a few times before (attempts at the cambelt, then to put the unneeded new large arm on)
It's getting it back on that's fun. That engine's bloody heavy then comes the pushing, pulling and hammering to get the mounts lined up
After all this if it turns out to be the dome-shaped mount I'm going to scream!
BTW, how tight should the joints be? I've done them tight enough that I can't move them, but I dunno if there should be movement or not
Posted: Wed Nov 21, 2007 1:33 pm
by mjb
It just took 22 minutes to replace the mount in your pic, including a few talking to colleagues (did it in the car park during lunch break). Not bad eh?
It's made a noticeable difference to how the car drives, but so did the last part of the mount I replaced. Only time will tell if it's the other bit I guess...
Still want to know how tight I should do the joints... :/
Posted: Wed Nov 21, 2007 6:14 pm
by mjb
mjb wrote:After all this if it turns out to be the dome-shaped mount I'm going to scream!
ARRRRGGGGGGHHHHHHH!!!
Posted: Wed Nov 21, 2007 6:27 pm
by TooT
Hmmmm let me think............
Phone call to the dealer tomorrow for a dome-shaped mount by any chance?
Posted: Wed Nov 21, 2007 7:29 pm
by jameslxdt
make sure its not loose, if its not, then make sure the welds havent failed and its partially ripped out
, not uncommon unfortunatley
and it should be as tight as you can do it
Posted: Wed Nov 21, 2007 8:55 pm
by mjb
jameslxdt wrote:make sure its not loose, if its not, then make sure the welds havent failed and its partially ripped out
welds in what, the bracket between the bit you took a picture of (todays replacement) and the bit that attaches to the engine (last week's)? Hmm might have a look at that at the weekend when i attack the thermostat (and dome-shaped mount if i can get one in time)
Posted: Thu Nov 22, 2007 8:41 pm
by jameslxdt
where that bush is screwed into the engine bay near the coolant and pas reservoir, the threaded section is where the welds fail
Posted: Thu Nov 22, 2007 9:25 pm
by mjb
jameslxdt wrote:where that bush is screwed into the engine bay near the coolant and pas reservoir, the threaded section is where the welds fail
You mean on the BODY???
funnily enough my middle exhaust section's started blowing... guessing was probably caused by the engine banging about
Posted: Sat Nov 24, 2007 2:23 pm
by jameslxdt
mjb wrote:jameslxdt wrote:where that bush is screwed into the engine bay near the coolant and pas reservoir, the threaded section is where the welds fail
yep
Posted: Sat Nov 24, 2007 6:13 pm
by mjb
sh*t. I ain't used a welder since I was about 13 and don't intend to start again on my precious. Guess this could be expensive
Any idea just *how* expensive it's likely to be at £50/hr?
I'm starting to think I'm not going to get the car through its MOT in Feb... This mount needs sorting out as a priority before it destroys the car, then i need 5 tyres, tax, and whatever in the steering got me an advisory last time ("swivel joint" - wtf?)... Doubt I'm going to be able to afford it
Might have to SORN it for a month or two
Posted: Sat Nov 24, 2007 6:28 pm
by jameslxdt
get it mot'ed now so you've got enough time to fix it
