help plz?
Posted: Sun Nov 25, 2007 10:31 am
by bloodredwarlock
wonder if any1 can shed some light on my problem. Im getting a whinging sort of noise when i turn my steering wheel at v.low speed e.g parking or taking off, i think it could be my power steering pump but i aint sure and dont want to start sorting bits that are fine. any suggestions on what it is and how much it would cost to sort cheers.
Re: help plz?
Posted: Sun Nov 25, 2007 1:36 pm
by Ian
this whinging noise, You wouldnt happen to be out with your wife/girlfriend when it happens each time would you ?
Re: help plz?
Posted: Mon Nov 26, 2007 4:27 pm
by legoless
Heh!
I`ll ask the obvious question just incase.. is the auxillary belt ok? not old and slippery etc
Re: help plz?
Posted: Mon Nov 26, 2007 4:35 pm
Low PAS fluid?
Re: help plz?
Posted: Mon Nov 26, 2007 6:26 pm
by bloodredwarlock
Re: help plz?
Posted: Mon Nov 26, 2007 7:58 pm
What, the steering? Sounds very dangerous!
Still not sure about this "whinging" - "do we really need to drive this fast are we in a hurry watch out for that blade of grass could you turn the music down I'm cold I'm too hot don't forget to turn left here..."
Re: help plz?
Posted: Tue Nov 27, 2007 12:05 am
by bloodredwarlock
no its the car that whings, the bird knows the score, shut the f*ck up or you walk!
Re: help plz?
Posted: Tue Nov 27, 2007 11:41 am
by teamster1975
I know what you mean, it's like a groaning noise when you go full lock, like the pump is about to have a heart attack. My mate's astra does it.
Re: help plz?
Posted: Thu Nov 29, 2007 8:54 am
by bloodredwarlock
problem solved. Having only recently acquired the car i thought id best check the fluid levels first b4 doing major work. The person i bought the car from had changed the power steering fluid but it wasn't even close (bout 2 inches away) to the minimum level indicator. I topped up and put some of this wynns stop leak stuff in beside it no more whines or groans.
Re: help plz?
Posted: Thu Nov 29, 2007 9:09 am
I wrote:Low PAS fluid?
bloodredwarlock wrote:problem solved. Having only recently acquired the car i thought id best check the fluid levels first b4 doing major work. The person i bought the car from had changed the power steering fluid but it wasn't even close (bout 2 inches away) to the minimum level indicator. I topped up and put some of this wynns stop leak stuff in beside it no more whines or groans.
I got something right!!!!
