Page 1 of 2
406 sri turbo exhaust
Posted: Sun Dec 09, 2007 6:36 pm
by sriturbO
406 sri turbo exhaust pipe diameter anyone know?
Re: 406 sri turbo exhaust
Posted: Sun Dec 09, 2007 8:34 pm
by mikey s
2.5 inchs.
Posted: Sun Dec 09, 2007 8:55 pm
by sriturbO
ok cheers mate thinkin of a 3inch or maybe 3 1/2 inch custom one wot u think
Posted: Sun Dec 09, 2007 10:16 pm
by mikey s
in all honesty unless your looking for plus 200bhp stick with 2.5inch. the guys on 205 gti drivers have done some tests on 2.0 turbo exhausts and the general consensus is 2.5 inch seems to work the best. peugeot tend to make some cracking standard exhausts, all length tuned to perfection etc. i wouldnt waste your money on a stainless one, just buy a good standard one.
Posted: Sun Dec 09, 2007 10:24 pm
by sriturbO
cheers mike i will be going for around 200 bhp or maybe more so ill go with 3inch as i cant find a standard one in stainless anyway and i also cant find a decat for it so kinda makes sense to get it all done in 3 inch pipework
Posted: Wed Dec 12, 2007 11:34 am
by Deano
sriturbO wrote:cheers mike i will be going for around 200 bhp or maybe more so ill go with 3inch as i cant find a standard one in stainless anyway and i also cant find a decat for it so kinda makes sense to get it all done in 3 inch pipework
Just a note to remember if you are in the UK then you will need to refit a cat for MOT each year
Posted: Thu Dec 13, 2007 2:21 am
by pugsport
I had a powerflow custom exhaust put on mine 6yrs ago only cost £240, much cheaper than OEM plus lifetime garuantee so it is not a waste of money, considering I would normaly have to replace standard exhaust every 2 or 3 yrs!
A 2.5 would be okay for 200bhp.
Posted: Thu Dec 13, 2007 2:25 am
by pugsport
Hi Deano, is it cold enough for you?
Posted: Thu Dec 13, 2007 12:31 pm
by Deano
TO COLD :(
Posted: Thu Dec 13, 2007 3:00 pm
by Tiny Tim
As far as exhaust systems og on petrol turbos, for the best performance you want the system to be as short and large a bore as possible with as little bends. Its all about restrictions. Mind you, if you're going to stick a large bore exhaust on and keep the standard downpipe + turbo elbow, there's no point.
Posted: Thu Dec 13, 2007 11:32 pm
by mikey s
im not sure i completely agree with you there. if the bore is too big, gas velocity is reduced to such an extent that reversal occurs which is a bad thing. if you could put up with the noise having no silencers in a turbocharged petrol exhaust is good. the turbo creates all the backpressure that the engine needs.
the turbo elbow on the xu10 engine is part of the exhaust turbine housing so the only way to change this would be to change the turbo.
Posted: Fri Dec 14, 2007 10:15 am
by Tiny Tim
Sorry mate, but the theories wrong... you dont want back pressure on a turbo'd engine.. think about it.
Posted: Fri Dec 14, 2007 10:19 am
Just the thing for a two stroke tho :P
Posted: Fri Dec 14, 2007 11:11 pm
by sriturbO
ok im going for 3 inch decat into 3inch straight through center into a 3 inch baffled box of the tombstone variety
Posted: Sat Dec 15, 2007 9:47 am
by Tiny Tim
Why not go for a side exit? 8)
