gti-6 advantages
Posted: Sat Dec 15, 2007 5:11 pm
by mypugscool
is there any advanages in fitting gti-6 inlet and exhaust manifolds cams etc and will they fit ok on my 1.8 16v
Re: gti-6 advantages
Posted: Sat Dec 15, 2007 5:14 pm
by jameslxdt
they do fit and make substantial difference, ive still got an exhaust manifold for sale if you want
Posted: Sat Dec 15, 2007 5:19 pm
by mypugscool
whats the difference between mine and your one
Posted: Sat Dec 22, 2007 4:29 pm
by mypugscool
has anyone done this mod on theirs if so was there much gain
Posted: Sat Dec 22, 2007 5:10 pm
by acqu135c3
Does anyone know if you could fit an entire GTi-6 head? and would there be any advantage to doing so?
Posted: Sat Dec 22, 2007 9:03 pm
by mikey s
there the same casting but the valves are a different size iirc.
Posted: Sun Dec 23, 2007 8:30 pm
by jameslxdt
mucho larger valves, double valve springs and a ported combustion chamber, the cylinder head, manifolds and ingition system is the only difference between the XU10J4R and the XU10J4RS
Posted: Wed Dec 26, 2007 1:26 am
by acqu135c3
So it might be worth using the whole gti-6 cylinder head on a 1.8/2.0? I suppose then to see the best gains the ecu would need remaping unless a gti6 ecu would work in the 406. Only theoretically speaking, I don't plan on doing it.
