406 HDI fuel filter renewal
Posted: Thu Jan 10, 2008 11:04 am
HI,
I'm new to this site and wondered if I get some advice.
I've just bought a 406 HDI 2.0 110bhp 53 plate. I bought a Haynes manual that lists service items so I thought i'd work through these because I can't be sure how often the car has been maintained.
I bought a new fuel filter element from Peugeot but when I came to fit it there was no drain screw on the front of the housing so I had to ring around and find out why. Turns out that mine has a Seimens filter housing which has the drain hole blanked off but underneath there is a toothed wheel that you unscrew to drain the fuel out. Anyway, I fitted it with no problems. (Thanks for tip on here about using an oil filter removal tool to get the filter housing cap off).
Problem is, before I found this site, I posted a question about how to change a fuel filter on another site and by the time I had read it I had already done it.
On the reply I got they said "DO NOT open the filter housing and change the filter element, go to your dealer and buy the whole housing". They said that by opening the fuel filter housing you risk £2500 of damage to a high power pump or something due to contamination (dirt).
Does anyone know if this is likely. The haynes manual says that the element should be changed every 24,000 miles?
Thanks for any advice
Mark
Mark
