406 hdi 110 air con issue
Posted: Wed Jan 16, 2008 9:11 pm
by alexpogg
hi again, forgot to mention another problem...when i turn on the air con i cant hear it "click in" under the bonnet which i presume you are supposed to hear, could this be a fuse, i never really use it and now it appears that it dosent work, i have been told that it needs re-gassing ?.....any advice appreciated.
Re: 406 hdi 110 air con issue
Posted: Wed Jan 16, 2008 9:38 pm
Get it re-gassed?
Posted: Wed Jan 16, 2008 9:40 pm
by alexpogg
re-gassed was something i was told i should do, does that not make sense to you ?
Posted: Wed Jan 16, 2008 11:36 pm
by mikey s
any decent aircon place will leak dye it for to check if the system has a leak anywhere. its a false economy to just get it regassed.
Posted: Thu Jan 17, 2008 8:11 am
Indeed, if they're any good they'll do it as a matter of course but it's probably best to ask for it, just in case. I have a feeling that if you leave the system empty it'll develop more faults. They do tend to loose pressure over time so it's probably normal.
Posted: Thu Jan 17, 2008 8:44 am
If your car is 6/7/8 years old it is almost certainly the condenser is perished.
It is VERY common here.
There is also a piece of a/c pipework that corrodes under the battery but the condenser is favourite.
The condenser is £300.00 fitted, or about £170.00 if you do the donkey work.
Posted: Thu Jan 17, 2008 9:08 am
That's a bastard. Still, you won't know until someone tried to pressurize it. My D8's 10 years old, the system was empty last year so Pug used the dye on it, it's still holding pressure a year later. But then I'm not in the UK and they don't rush out and shovel salt everywhere the moment there's a bit of a nip in the air.
Incidently, they have started using salt here, although sparingly (mainly due to them being caught out) and not NaCl (only good down to -5).
