Slow Turbo exec
Posted: Fri Feb 29, 2008 12:13 pm
Hi guys,
I brought a 96 2L turbo exec a year ago and love it to bits. I brought it with all mods it's got on it.
I find that it is quite sluggish, I know it is a heavy car, but before I had a 309GRi with the 1.6injection engine and it used to fly off the lights.
A friend of mine who is into turbo cars noticed the atompheric blow off valve was jammed, so we replaced that and now she hisses nicley, but to little power gain.
I did have a problem with the turbo inlet being blocked and it wouldn't rev past 2500rpm, but thats all sorted and now have a cone filter on it for a nice engine note. But when testing it, we ran it without the pipe from the tubro to the engine and could hear the turbo in full glory spinning up and whistling down. We have bypased the valve which pulses the vacum pipe to the wastegate as they apparently have a habbit of going, so it should be quite aggressive when the turbo spools up at revs.
But even with these she is sluggish, I got beat by a f**cking clio the other day
and reading all forums and whatnot about the exec turbo, it is meant to be quite rapid.
It will hit limited top speed, but just acceleration isn't what I would expect, in first gear I feel the turbo pulse, but not in other gears. I havn't been in another 2L turbo as I don't know anyone with the rare beast, so I can't compare, but even with HDI's, you feel the turbo kick in, but not with mine
Oh, and just fyi, I have a random slight tapping on the top of the engine, people say it is a gunked up tappit ot tappit shaft, it is more noticable when cold starts, kind of like a cracking noise but with no rythum, just random, I got told not to worry about it and it would be very expensive to fix.
She also gets hot when not moving, in most traffic buildups, the temp goes up to 90-100 and the fans have to keep it cool, but at 30+ she stays at 75-80ish, it doesn't seem to stay steady. My old 309 used to heat up quickly but I knew I had a blown oil seal on one of the pistons and the oil used to bubble up and become like mayo in the filler cap. Nothing of the sort on this one.
I have thoughts about adjusting the wasegate to increase boost, but I don't have a boost gadge and I worry about blowing piston rings and head gaskets like my old one.
Can anyone suggest what to do with her or where to take her? I live in Chester but havn't been here for long so don't know any places around here. I was thinking of taking her to pug for a full service and ask for them to check the turbo and boost pressure and paying thorugh the nose for it?
I have been under the car and the turbo itself looks too new for the car age, it's the correct Garrett T25 so I think it's been replaced at some point because it looks newish and clean.
Any input would be nice as I just feel a bit dissapointed to be driving a turbo car which supermini's can beat
