Gtx power prob
Tco
Gtx power prob
Post by Tco »
Hi all. Forgive me if this prob has already been answered elsewhere but I cannot find anything.
I own a 406 GTX Hdi. Its been great up until about a few weeks ago when the exhaust sounded like it had a very very slight blow to it. It never really got any worse so I have left it as is until it really needs doing. Yesterday when I left work I noticed a distinct lack of power. Very flat response from the engine and the exhaust sounded a tiny bit more 'blowy'.
Today took wifey to the shops and the power loss was even more evident. Exhaust sounds much the same (slight blow) but when I change gear at around 4000 revs there is more of a puff of the old diesel smoke than usual. As of twenty mins ago the power is awful and the engine management light has come on.
A few years ago I had a VW corrado and the symptoms were similar when my CAT broke up inside. Spoke to a friend and he said it may be turbo pipe split or the catalyst.
Any ideas?
I phoned main dealer but the costs have scared my innards out in large volumes!! ( I think you get my drift ).
Love the car but will have to do the work myself as funds are very tight.
Been looking on the net for ages and finally found this site. Nice to see some fellow 406 lovers. :)
Cheers
Andy
TCO
Re: Gtx power prob
Difficult one in a way - if you say the exhaust has been/is blowing then it's possible the CAT has broke up and the back pressure is forcing the blowing out of the flexible joint above the CAT or some other joint.
It is also possible that the air flow meter is knackered, the EGR valve (although that doesn't normally hold you up), throttle position sensor, vacuum pump etc etc. you ought to get the ECU codes read.
One thing you could try is getting someone to give the car a good rev whilst you hold your hand under the tail pipe - you should get a really strong blast of air as the turbo comes in, if it feels a bit weedy then the exhaust could be restricted.
If you're getting a weird whistle or air rushing sound then the intercooler hoses may be leaking.
See what some others say too.
Welly.
(Welcome :cheesy: )
Tco
Re: Gtx power prob
Post by Tco »
Cheers buddy, i'll have a look today. Thanks for the prompt reply.
Tco
Re: Gtx power prob
Post by Tco »
Re: Gtx power prob
Get your head under the car and find out where you're blowing. I'm with welly on this though, I'd be looking at the cat
