Page 1 of 2
Does the HPi have a MAF Sensor?
Posted: Mon Apr 21, 2008 6:00 pm
by DaiRees
Right, everyone's on about MAF sensors, in fact they seem to be a common theme throughout about 90% of our recent threads. Now I reckon this hesitation and lack of pull at low revs is a symptom that's familiar to me too, so was wondering if mine has a MAF sensor, and if it has where is the bloody thing so that I can give it a clean?
I'll get a photo of my engine bay up later and you knowledgeable types can lend me the benefit of your expertise by adding some pointy things....
Re: MAF Sensor
Posted: Mon Apr 21, 2008 6:29 pm
by DaiRees
Re: MAF Sensor
Posted: Mon Apr 21, 2008 6:41 pm
Christ knows, can you find it on Service Box and work backwards?
Re: MAF Sensor
Posted: Mon Apr 21, 2008 7:08 pm
by DaiRees
Who knows what they'll call it though. last week I bought a little bit of plastic interior trim from the stealer, pugs description was "plug towball"
Re: MAF Sensor
Posted: Mon Apr 21, 2008 7:27 pm
by puggy
if you go on service box and look in air filter for your car all the piping should
come up and it should be part of that
Re: MAF Sensor
Posted: Mon Apr 21, 2008 7:35 pm
by DaiRees
Re: MAF Sensor
Posted: Mon Apr 21, 2008 7:51 pm
by puggy
ok will stick my neck out on mine (yes i know its a hdi ) its on the pipe
going
FROM airfilter box so i would guess around here
Re: MAF Sensor
Posted: Mon Apr 21, 2008 8:02 pm
by DaiRees
That's the Throttle Control.
Just been reading a Shitroen forum, (C5 has the same engine) and found this...
Looks suspiciously like something to do with the Air Flow Sensor (or is it an MAP sensor?).
These engines have a MAP sensor,its located in the pipe at the brake servo though.
So now what the hell is a MAP sensor? is that something to do with geography?
Re: MAF Sensor
Posted: Mon Apr 21, 2008 8:05 pm
by puggy
Re: MAF Sensor
Posted: Mon Apr 21, 2008 8:09 pm
Manifold Absolute Pressure?
(Mangled Aching Penis??)
Re: MAF Sensor
Posted: Mon Apr 21, 2008 8:25 pm
by DaiRees
Item #10, pressure sensor?
Re: Does the HPi have a MAF Sensor?
Posted: Tue Apr 22, 2008 8:12 am
Your engine doesn't have an air flow meter - it senses manifold pressure (a MAP sensor) it measures absolute pressure and the ECU converts this into an air volume.
They are small sensors, screwed into the inlet manifold somewhere.
Dai - what's your throttle action like? only that throttle cable route looks a bit restictive to free movement - my HDi cable takes a similar route but isn't held back against th bulkhead like yours. Maybe the throttle cable is 'jerky' resulting in your 'miss-fire' ?
Posted: Tue Apr 22, 2008 9:10 am
by DaiRees
The throttle's pretty smooth actually, and the hesitation occurs if you accelerate with the cruise too, so I don't think it's the throttle cable.
So do you reckon this MAP sensor could do with a clean if I can find it, or is it better to leave well alone?
Posted: Tue Apr 22, 2008 9:14 am
Have you got insurance?
Posted: Tue Apr 22, 2008 9:17 am
by DaiRees
