406 front mount help
Posted: Mon May 05, 2008 7:38 pm
by BRADYBOY2K8
i'm doing a front mount intercooler on my exec turbo and wondered, i'll obv need 2 remove the old cooler, but the 2 fans in front, will my car over heat if i take em out?? thanks
Re: 406 front mount help
Posted: Mon May 05, 2008 7:58 pm
by jameslxdt
take them out and see what happens
Posted: Tue May 06, 2008 1:02 pm
by mjb
BRADYBOY2K8 wrote:i'm doing a front mount intercooler on my exec turbo and wondered, i'll obv need 2 remove the old cooler, but the 2 fans in front, will my car over heat if i take em out?? thanks
Yes.
You will be able to travel at speed fine, but as soon as you drop under 30mph with a warm engine you'll overheat in a couple of minutes, if that.
Posted: Wed May 07, 2008 12:40 am
by BRADYBOY2K8
would co2 spray help 2 prevent this? because really i dont see the point in having a front mount 2 cover it up the gay fans, lol
what if i kept the fans but behind the front mount with air directed towards them using ducting stuff??
Posted: Wed May 07, 2008 7:54 am
by Blue406
Bit of a silly question really.
The fans are there for a reason, much like the wheels and tyres at each corner of your car!
Posted: Wed May 07, 2008 7:59 am
by Blue406
BRADYBOY2K8 wrote:would co2 spray help 2 prevent this? because really i dont see the point in having a front mount 2 cover it up the gay fans, lol
If you do it right, might work. Remember to reverse the motors, or you'll just blow the air AWAY from the engine!
I think you're shaping up for an overheat though.
Posted: Wed May 07, 2008 8:05 am
by BRADYBOY2K8
cheers, once i take everything off, i'm hoping i can move the fans inplace of the old cooler ( still drawing air towards the engine )
it looks as if there is enough room to mount a new cooler and position the fans further back
dont know if that makes sence to you :S lol
Posted: Wed May 07, 2008 12:36 pm
by Busman
Why would you want to remove the cooling system from the engine? Surley this would result in over heating? These fans tend to be put there for a reason.
Posted: Fri May 09, 2008 9:05 am
by BRADYBOY2K8
i know there 4 a reason but i need a way round it, how do other cars with front mounts run with out over heating??
i'm hoping i can mount the front mount in front of the fans and direct air to them via induction hoses, not sure tho
Posted: Fri May 09, 2008 10:26 am
by puggy
cant you mount it lower down behind the grill in the front
bumper and re-plumb the pipe work ??
Posted: Fri May 09, 2008 10:57 am
by Blue406
BRADYBOY2K8 wrote:i know there 4 a reason but i need a way round it, how do other cars with front mounts run with out over heating??
They design the engine bay and cooling system accomodation to account for it.
