clutch problem
clutch problem
hi guys - i had a brand new clutch fitted to my peugeot 406 hdi 1999 v reg about 5 months ago....i noticed that as i drove the car away, there is a judder in first gear and also in reverese as well...i took it back to the mechanic who said it just needs bedding in with the flywheel as it was a new clutch and i should give it a few 100 miles and it would be ok..i have now done nearly 1000 miles, dont drive far just to work and back and the judder is still there, specially when im on a hill it seems to be worse....sometimes it is fine for a day or so drives as it should but most of the time its there....the mechanic is a very honest and trusted bloke and was highly recommended..he said the clutch is fitted perfectly...either the new clutch is slightly warped or the flywheel is well worn...i can get a replacement clutch as it is under warranty but im not paying again to have it fitted, then again it could be the flywheel..any ideas guys...cheers ?
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Re: clutch problem
Oh dear
is it a 110 hdi or 90?
Re: clutch problem
Yes, if it's a 110 it could be the flywheel, it could also be an engine mounting of course.
Re: clutch problem
Yes totally agree steve i would eliminate the cheaper option first.
Re: clutch problem
hi guys...its a 90 hdi model....ill get the mechanic to look at the engine mounting, as im having a new tensioner, fan belt and one of the anti roll bar linkages is making a knocking noise when i go over some bumps...
