D9 HDi Running Temp
cliver
D9 HDi Running Temp
Post by cliver »
Hello,
Just so I know at what point to start worrying - what water & oil temperatures are considered usual for the HDi (110) :?:
Many thanks for any opinions.
Re: D9 HDi Running Temp
Pointing straight up - temp doesn't go much above 90, oil sometimes creeps up to the second division above 90 ( :? 140-90=50/3= 16.6666666, which would make it 106.66666666 stupid gauge)
My tempgauge points directlyto the number 9 of "90".
I don't have an oil temp gauge :( but I do know that engine oils' ideal running temp is between 90 and 105 deg C (motorways).
jamjar1383
Post by jamjar1383 »
i own a d8 hdi 110 and the temp doesnt really go above 70 unless im stuk in traffic.
hope that helps
d9 hdi 90 rapier estate
muffindell
2.2 16v
Post by muffindell »
Water should run between 85 and 90ish depending on what stat installed. Oil around 105 depending on load and quality of oil.
jamjar1383 wrote:i own a d8 hdi 110 and the temp doesnt really go above 70 unless im stuk in traffic.
Umm, you're looking like the odd one out here, what does it get to when you're stuck in traffic?
jamjar1383
it goes up to 90 an then cools back down 70. when i asked the main dealer he said that it was correct because i got one of the very first hdi's ( ie 1999).
Fair enough :cheesy:
muffindell
2.2 16v
There isnt a stat rated at 70C, usually 85C and that's the temp which should be maintained (other than heavy load or very hot day). Either your temp gauge is incorrect or the stat is missing :shock: or jammed open.
