Oil leak!
Oil leak!
Hi chaps :)
My car is booked in for its MOT on Friday, can it be failed for having an oil leak?
I've got a weep coming from the rocker cover gasket and another coming from somewhere on the back of the engine.
I'm going to crawl underneath and spray some degreaser around to clean it up & make it less obvious!
Re: Oil leak!
Is it life-threatening? Is it likely to make your car unsafe? Are you putting too many nasty things into the air?
Didn't think so :cheesy:
Hands up who doesn't have an oil leak...
Re: Oil leak!
That'll do nicely! :cheesy:
Cheers Steve :)
Re: Oil leak!
Should have seen how gunky my tubby's engine was! :lol:
As long as it's not dripping, there'll be no problem with the MOT
Smelliot
Re: Oil leak!
Post by Smelliot »
Both hands in pockets.... mmmm... anyway
I've not got an "oil leak"...yet but the back of the sump is almost slimy with oil and dirt and whatnot..., also, the area around the boost blow off valve does need cleaning every now and again as that gets nice and oily.
I just hope the oil seals in my cooked turbo hold out whilst I need the car this week and then hopefully Niz will have kindly referbed me a replacement turbo to put on, this driving like a grandad is killing me... but the milage I'm getting is at record high for my car.. :)
As long as the oil isn't spewing out all over the road to make hazardous conditions for other drivers, then you should be fine on the MOT.... but then if it did all go, how much of a problem would 5 liters of oil do? pah.
Good luck mate
2.0L turbo D8 exec saloon
Re: Oil leak!
mjb wrote:As long as it's not dripping, there'll be no problem with the MOT
Actually there is a bit of a drip but it only shows if you've given the car a good thrashing :oops:
I'll have a mop up and hide all the evidence!
Cheers Matt :)
Re: Oil leak!
A smallish leak won't be a concern to the MOT.
My HDi's block is wet at the back on the bulkhead side, more to the cambelt end - I daren't find out where it's coming from though :|
Re: Oil leak!
Smelliot wrote:I just hope the oil seals in my cooked turbo hold out whilst I need the car this week and then hopefully Niz will have kindly referbed me a replacement turbo to put on, this driving like a grandad is killing me... but the milage I'm getting is at record high for my car..
Oh is Niz still around? I did wonder as he hadn't been here for a while.
I asked him for advice on a huuuuge list of faults and I guess he though sod that! :lol:
Smelliot
Re: Oil leak!
Post by Smelliot »
That maybe my fault then as I've been on to him about my turbo 'issue'.... :oops:
I've got a list of things as long as my arm (just wish it was as long as something else), but I guess working through them one by one will get there in the end.
btw... how do you quote from a user?
Re: Oil leak!
Hit the "QUOTE" button by the post you want (also works from reply, just scroll down to the post)
You can also edit them if so desired :cheesy:
Smelliot wrote:Ware zat bustard Niz then?
Or do the same thing you did, but in the first box put
whoever you want to quote after the equals and in inverted commers wrote:e.g. (quote="Pope Benny")
Re: Oil leak!
I saw it Steve before you editted, you.. you.. you AMATEUR :P :P
:lol: :lol:
Re: Oil leak!
Hey, the board automatically parsed the quote so I had to change it!
Re: Oil leak!
steve_earwig wrote:Is it life-threatening? Is it likely to make your car unsafe? Are you putting too many nasty things into the air?
Got both hands up can't find oil leak anywhere :mrgreen: :mrgreen: :mrgreen:
Re: Oil leak!
Something else that wasn't in the parts bin while they were assembling it? :P
Re: Oil leak!
Yeah puggy they forgot to make yours piss oil out all over the place :P I'd get that seen too if I was you - doesn't sound right to me :)
