veg oil
Loveslug
veg oil
Post by Loveslug »
Just a quick one for the guys in the know!
Can i safely run my 406 on a 50/50 mix of veggie oil?
Many thanks
ianst28
2.2 16v
Location: sunny wirral (who am i kidding it's always bl&^%y raining)
Re: veg oil
Post by ianst28 »
truth is it depends on what 406 you have
if its a 1.9td then it seems ok
if its a 2.1td then no
if its an hdi then hell no
only problem is veggie oil ain't that cheap anymore i'm paying about 85p a litre and it's alot of grief putting it in the tank
If at first you don't succeed, skydiving is not for you !!!!!
ddoherty406
Re: veg oil
Post by ddoherty406 »
have u been using it long ian? does it do much damage to the engine, or clog up the filter/pump/pipes?
ianst28
2.2 16v
Re: veg oil
Post by ianst28 »
been using it for about 12-16 weeks pretty much since i got the 406
doesnt seem to do any damage only thing is if you run it at a higher mix of oil the car is hard to start in the morn and hunts till it warms up
i've been changing the fuel filter every 3-4 weeks but i do about 1000-1500 miles a week and i get the filters at cost +10%+vat
poddack
Re: veg oil
Post by poddack »
Why can't the 2.1td run on veg oil?
Hmmmm, straight 6 goodness!
Re: veg oil
'cos it'll kill the fuel pump. Apparently it's like light bulbs, it might last for quite a while or it might go in a matter of seconds.
Re: veg oil
steve_earwig wrote:it's like light bulbs, it might last for quite a while or it might go in a matter of seconds.
You can buy those too eh? :)
Xantiaman
Re: veg oil
Post by Xantiaman »
1.9 TD on a bosch pump will run veg very happily you just have to watch out for old seals perishing and causing a leak, and also blockages caused by the sludge in the tank being picked up by the veg.
2.1 TD uses a Lucas fly by wire pump, they will not tolerate a higher viscosity fuel (like the Lucas pump on the 1.9 TD, usually late 306) and they will snap in half if you risk it. They are a bit better mpg wise so best stick to biodiesel.
Gareth
2000 Xantia Activa CT Turbo
1990 MG Maestro Turbo
Re: veg oil
Welton wrote:You can buy those too eh? :)
Yes, they're a little bit cheaper and easier to fit though. :P
ianst28
2.2 16v
Re: veg oil
Post by ianst28 »
lmfao you think
priced a front headlight bulb for a mate's vectra it's a fairly new one the git
only place that does it is the stealers and they want ................... wait for it ........................ £376 & gordons cut
ok it does come with the complete headlamp (it's a sealed unit apparently) and vaux do give you a 10 year warranty unless your kid twats a cricket ball into it
Re: veg oil
Christ on a bike! Won't be buying a Vectra then!
