Clutch master cylinder
poddack
Post by poddack »
Any ideas on replacing a clutch master cylinder on a 2.1td? Is there much ro dismantle before I can access it?
Hmmmm, straight 6 goodness!
Re: Clutch master cylinder
406 hydraulic clutches are sealed-for-life units, you need to replace the lot (master, slave and reservoir). Thankfully it's an easy job. The cylinder just unclips and the cylinders just need pushing/levering in while turning anticlockwise to undo. You may need to take off a few plastic panels at the back of the engine bay and possibly the air box (dunno where that is on diseasels) but it's a 20-30min job to replace one on a petrol turbo.
mjb wrote:406 hydraulic clutches are sealed-for-life units...
Not on later HDis they aint! :P
sh*t i'm having a bad day :cry:
They are on 2.1s though. I'm having a wierd day myself 8)
poddack
Post by poddack »
Replaced and fitted, works nicely thanks
