Hi All ,
will brembo brakes from a 406 coupe fit on a 98`406 2.1 TD ??
Also have an issue with surges, my car when its revs high around 4000 revs the car switches off completely and then on again ?!?!? I also notcied at high revs the lights dim and the stereo sometimes resets - I obvioulsy checked the alternator but my electrician says it OK ??
Any thoughts ??
2.1 TD - Brembo Brake Question ??
406 (98) 2.1l TurboDiesel
Re: 2.1 TD - Brembo Brake Question ??
With bigger alloys, yes, but there's little point on a car like thatVella76 wrote:will brembo brakes from a 406 coupe fit on a 98`406 2.1 TD ??
My guess is a dodgy earth connection. Somewhere.Also have an issue with surges, my car when its revs high around 4000 revs the car switches off completely and then on again ?!?!? I also notcied at high revs the lights dim and the stereo sometimes resets - I obvioulsy checked the alternator but my electrician says it OK ??
