Re: Brake Lights
Posted: Tue Sep 02, 2008 9:29 pm
Hold on, the rest of the lights work so you think it's a fuse? Did you look at the bulbs? If they're ok I think you need to check the wiring 'cos it would be mad to have a separate feed and fuse for the high level light.
Hold on, it is a Peugeot...
Re: Brake Lights
Posted: Tue Sep 02, 2008 11:32 pm
by 406silverhdi
the brake lights are a different elements to the tail lights
replace the correct bulb as a starting point
Re: Brake Lights
Posted: Wed Sep 03, 2008 8:59 am
by mbell666
the pedal sensor would effect all brake lights.
Re: Brake Lights
Posted: Thu Sep 04, 2008 1:56 pm
by mjb
supafrisk wrote:I remember a '6 that went for test and had no brake lights, it was a sensor/switch in the driver's footwell
Can't remember if it affected the high level one or not though.........
It affects all three brake lights, as I discovered when I was playing around with the switches for the cruise control...
