resetting service indicator
Posted: Thu Sep 25, 2008 8:20 pm
Anyone explain what / where button 1 is for resetting service indicator i have an extract from pdf file for 406 which goes .....
Resetting the service indicator
Your PEUGEOT dealer carries out this operation after each service.
However, if you carry out the service yourself, the reset procedure is as follows:
– Switch off the ignition.
– Press and hold button 1.
– Switch on the ignition.
The display begins a 10 second
countdown.
– Keep button 1 pressed for
10 seconds.
Steve
countdown.
10 seconds.
Steve
