think sorted the non starting unplugged the blower it starts
Posted: Thu Nov 13, 2008 2:18 pm
by dragonslayer
hi guys think i found my problem.i turned off the blower and the car now runs and the alternater now charges the battery.is bthere an erth on the blower or unit or is it faulty ignition switch any info would be great
cheers dave
Re: think sorted the non starting unplugged the blower it starts
Posted: Fri Nov 14, 2008 5:16 pm
by SimonTNUK
You could have posted this in your original topic mate.
I posted on that one before I saw this one. Now I feel aggrieved that I wasted my time posting on your first question when you already knew the answer :roll: .
If you unplugged your blower and now your car starts and charges properly I would suspect that it is your culprit.
The blower switch is still in and plugged in I assume ?
As you modifiy car switches with leds, presumably you've got a multimeter. Use that to check for a short from the blower switch.
If that is ok then put a new(er) blower in.
If you start loosing charge again, its something else :twisted:
Posted: Sat Nov 15, 2008 11:58 am
by dragonslayer
hi where is the blower switch located?
cheers dave
