Intercooler Question
Posted: Wed Jan 14, 2009 2:04 pm
by lynneandcrow
Hi there again I am looking for sme info. My intercooler has blown and I am looking to get some info on it before I make up my mind if I should upgrade or replace.
1. I am looking for the Dimensions (in mm Height Width and Length)
2. What other cars is the Intercooler on (i.e. 2.1 HDI etc)
3. If I upgraded would it be easy to fit an after market Intercooler without all the hastle of cutting bits of the bdy off??
Re: Intercooler Question
Posted: Wed Jan 14, 2009 2:47 pm
by mjb
2. XUD9TE (1.9TD), XUD11BTE (2.1TD), DW10ATED (HDi110)
Peugeot part 384F4, £279.44
Surprised according to servicebox the HDi134 doesn't have an i/c?!?
Posted: Wed Jan 14, 2009 2:59 pm
but according to Haynes it has both air to air and water to air
Isn't my 2.1's intercooler like a radiator, while the Hdis are a box next to the rad?
Posted: Wed Jan 14, 2009 5:31 pm
by lynneandcrow
Posted: Wed Jan 14, 2009 5:38 pm
by P?s?mies
lynneandcrow wrote:Hi there again I am looking for sme info. My intercooler has blown and I am looking to get some info on it before I make up my mind if I should upgrade or replace.
1. Original intercooler dimensions are: total 780mmx320mmx30mm (widht only core 600mm)
2. I think they are same size, not 100% sure.
3. Its quite easy to modify aftermarket one to same place as original one. It took about 4 hrs total when i upgrade this
http://i250.photobucket.com/albums/gg27 ... ooleri.jpg to its place. Core size is 550mmx230mmx76mm 2,5"
by omega
doesnt look to be a1,its got some damaged fins
Posted: Wed Jan 14, 2009 10:19 pm
by lynneandcrow
Thanx guys im going to get a recon one too risky thanks for all the replys
Posted: Wed Jan 14, 2009 10:41 pm
by puggy
If you have a local car radiator repair place take it there ,they will test it and prob
repair it for a lot less than a replacement
Posted: Thu Jan 15, 2009 12:01 am
by Doggy
mjb wrote:Surprised according to servicebox the HDi134 doesn't have an i/c?!?
steve_earwig wrote:but according to Haynes it has both air to air and water to air
The air-air is about the same as a 110, like
or
The water to air is used to heat the intake air during warm-up, (& FAP regen) and is difficult to geta picture of, looks like a s/steel tube running diagonally behing the radiator like this
You can (just) see the lower air pipe connection & lower water hose.
Posted: Thu Jan 15, 2009 6:57 am
That's quite a lot different to the 110 Doggy
even the radiator connection is different and I didn't know about the water/air exchanger!
Posted: Thu Jan 15, 2009 1:12 pm
by Doggy
TBH I've never really looked at a 406 110, but had seen the early 307 installation & a few 406 under-bonnet pics & assumed they were the same.
Posted: Thu Jan 15, 2009 1:14 pm
by StevieboyTD
I'm currently breaking a td xantia with an intercooler. I'll get a few snaps later and see if it's the one you need.
