406 engine Bosch or siemens
andrew1608
Post by andrew1608 »
I have the rapier 90 hdi how can i tell if the engine is bosch or siemens so i can get a tuning chip
Re: 406 engine Bosch or siemens
The engine is a PSA
The ECU will be a Bosch or Siemens, and you can either do a search to find out which, or open the bonnet and have a look what it says on it
madbaggie28
Post by madbaggie28 »
if you look on the rail on the engine there should be a sticker telling you which it is i think the early d9 was bosch and the later ones are simens
