110 not wanting to go
PeteL
Post by PeteL »
hi there just wondering if anyone has had the problem of putting their foot down in a 406 estate 110 and it seeming like ages before it gets going and seems to have some go in it.
if yes please let me know what it was / is as i have it and obviously need to get rid of it.
cheers
Pete
Pete.
poddack
Re: 110 not wanting to go
Post by poddack »
Turbo Lag?
Hmmmm, straight 6 goodness!
Could be air flow meter?
Throttle position sensor is a good one (but usually flags the engine light).
Faulty turbo wastgate control solenoid (bulkhead - try swapping with the EGR one?)
Bit tricky to say - it's not really a common problem :?
jasper5
Post by jasper5 »
In the last two weeks, I've had three vehicles with a similar fault.
One was a Peugeot Expert HDi with a split in the the rubber turbo pipe under the radiator.This also had black smoke out the exhaust when revved up.
Another Expert HDi was the air flow meter.
The other was a Mercedes 200 with an air flow meter problem.
Each vehicle was difficult to rev up and accelerate, the Merc wouldn't rev above 4,000 and was very slow.
PeteL
Post by PeteL »
cheers guys it looks like the air flow meter is getting looked at. can they be cleaned etc or do i need a new one ?
Pete
Pete.
Pugman406
Post by Pugman406 »
I had this problem the other week on my 110, after almost arriving home, i changed down and put foot down, and it came back to life, been ok since.
D9 2.0 HDI, 406, GLX, 110
jasper5
Post by jasper5 »
Pugman406 wrote:I had this problem the other week on my 110, after almost arriving home, i changed down and put foot down, and it came back to life, been ok since.
You are a very lucky person.I wish they could all be fixed as easy!
Did it go wrong all of a sudden, or was it a gradual deterioration?
Pugman406
Post by Pugman406 »
It was unexpected, drove throught the roads at work and i thought sumthin wasnt right, when i got on the main road, i thought the turbo had died or sumthing!
Anyway, i hope it doesnt return.
