The Funbus has finally failed me!
stevenlizuk
Post by stevenlizuk »
Went out to the trusty Funbus to come to work this morning and it wont start.
Turning over ok but not starting and no warning lamps are staying on.
Plenty fuel and the priming bulb is solid so not air in the system either.
Drove home fine last night without missing a beat.
Clues?
Cheers
Steve
(2.1td)
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
Re: The Funbus has finally failed me!
Voltage to glowplugs?
stevenlizuk
Was warm enough this morning to start without glowplugs, but yes there's power to them.
Thinking fuel solenoid.
swiss
Post by swiss »
Haynes recommends removing the solenoid, gutting it and replacing the shell as a temporary fix. Maybe try it, one more thing to eliminate if it's not the culprit.
Just remember you'll have to stop it locally or stall it :)
The man with no car
stevenlizuk
Tried to start her again this morning (too busy til now).
Buzzing from what I assume is the fuel pump solenoid in beside the ECU.
Then no blowers and the airbag light started flashing.
Thumped the solenoid and the car started and ran for about 5 mins then conked out again, immediately restarted but now with no airbag light?
New solenoid??
Any help is always greatly appreciated.
Steve
stevenlizuk
The Funbus lives and breathes again!
Finally had time and daylight enough to find out what was ailing the old beast.
Supply to the injection relay had rotted through just in front of the starter motor.
Rejoined her and off she went.
Might be worth a look for everyone else as it's the point where the trunking is held in place where the loom bridges from the car to the engine, lots of vibration and wear is inevitable.
Steve
Well done Steve! Definitely one for the knowledgebase! 8)
stevenlizuk
Rattly link arms and tracking next week, it never ends. :roll:
stevenlizuk wrote:Might be worth a look for everyone else as it's the point where the trunking is held in place where the loom bridges from the car to the engine, lots of vibration and wear is inevitable.
Steve
Thanks for the heads-up dude :cheesy:
stevenlizuk
After resting in the drive for ten days drove to work this morning and a stone from a tipper cracked the screen!
F@~**$£" (*^%$&*^ :x
Sob.
stevenlizuk wrote:After resting in the drive for ten days drove to work this morning and a stone from a tipper cracked the screen!
Did you get its reg? I'm sure you could claim that off his insurance!
stevenlizuk
Both of us in traffic on a 60mph A-road.
Not worth the Dukes of Hazard car chase to get him for him to say it wasn't him.
My insurance will cover it.
Bum and double-bum.
