thermostat 2.1 td
Posted: Sun Mar 01, 2009 11:49 am
by xabab
hi!
can anyone tell me, where can i find the thermostat on this engine?
is it here?
because i unmounted the hose and inside it was empty... is it there (or was, and fell apart and stuck in the radiator) or simply i'm searching on the wrong place?
Re: thermostat 2.1 td
Posted: Sun Mar 01, 2009 5:03 pm
by poddack
No, it's not there!
But just above there is a fuel filter with a blue and a brown plug on it. The blue is the temp sensor for the dashboard and the brown one is the temp sensor for the fans.
Posted: Sun Mar 01, 2009 5:04 pm
by poddack
Or for the correct answer, it's behind, at the bottom of the engine where the bottom radiator hose goes to the engine.
Posted: Sun Mar 01, 2009 6:08 pm
by xabab
thanks a lot! :)
in the service manual (not a Haynes 96-99, but another one 96-04) , that i have, are pictures of the thermostat position only of HDi and petrol engines, and a line under the pictures, that on each diesel model, the thermostat can be found on the upper left side of the cylinder head... so i didn't search under the car... so the book is a piece of c... :evil:
Posted: Sun Mar 01, 2009 10:47 pm
by teamster1975
xabab wrote:so the book is a piece of c...
That's why we call it the book of lies! :lol:
Welcome xabab :)
Posted: Sat Mar 07, 2009 12:08 am
by xabab
thnx :)
finally got home, and checked the thermostat housing... well, the engineers must have been reaaaaly drunk, to put that thing there...
"the book of lies" says, that there is a drain screw on the engine block, but i can't find it :cry: anyone? :oops:
Posted: Sun Mar 08, 2009 8:39 am
by mark21TD
Why drain the engine block when the stat housing is at the bottom of the system, just loosen the bolts slowly but not with your head directly underneath :lol:
Got to do mine soon (wont go above 70c) so let me know how you get on with bleeding the system afterwards.
