Aux Belt.
Aux Belt.
Hello,i have a 1997 406 executive estate 137000 miles, that i love driving but the aux belt broke last monday and with the bank holiday and my mobile mechanic not having the right kit it only got finished yesterday but now i have been left with this grinding sound which my mechanic says its something to do with the fluid in the power steering because its been sat for a week? and it should go after its been drove round for a week or so? also he only did the belt but a friends son said he should have changed the tensioner and roller? more worried about the grinding will it go or is it something more serious?
Re: Aux Belt.
That's a new one to me!Jenny wrote: i have been left with this grinding sound which my mechanic says its something to do with the fluid in the power steering because its been sat for a week? and it should go after its been drove round for a week or so?
Depends on what engine you've got in it, but generally no.Hello,i have a 1997 406 executive estate 137000 miles
Re: Aux Belt.
Only as a precaution, unless they're already goosed (enough to throw your aux belt off?)
Your mechanic is a monkey.
- Site Admin & Mad Biker!
Re: Aux Belt.
Welcome Jenny!
The bearings in the alternator might have given up, either that or the aux belt tensioner.
Your mechanic is telling you porky pies! Fluid settling my arse
The only way to tell is to take off the aux belt again & turn each component by hand; either that or hold a screwdriver on the alternator & see if you can hear the squeal!
Re: Aux Belt.
i had the same problem got the belt changed only for it to snap few days later turned out that the tensioner pulley had gone to ended up costing 200 quid
Re: Aux Belt.
Any grinding is a bad sign, the best way to tell is remove the belt and start the engine and see if it's still making the noise. As mentioned before, faulty pulley or alternator is possibly the cause for the belt snapping. The mobile mechanic should of checked this at time of fitting a new belt... Sounds like a bit of a cowboy
Hope you get is sorted
Dan
Dan
Re: Aux Belt.
Hi,
i hope you dont mind me just jumping in here but whilst everyone is on this topic. could the tensioner actually make a grinding/knocking noise? Its just as my 406 is currently suffering from this. Its only ocasional and it lasts for a few minutes. I am going to book it into a garage later on today but i wanted to make sure i was trying the right thing.
Many Thanks
Many Thanks
Peugeot 406 2.1TD
Re: Aux Belt.
If the bearings were seizing it is possible; mine was ok but I changed it anyway as I got a replacement with a job lot of parts. Alternator seems to be the main culprit.gingerryno wrote:Hi,
Many Thanks
Re: Aux Belt.
Hi, My peugeot was in the garage today and they did a fan belt replacement. they said that the tensioner didn't need replacing and they checked all of the other pulleys but they all seemed fine. i dont know if the problem will happen again but i am not to convinced that the problem has been resolved. does anyone else know what the ploblem may be?
Cheers
Cheers
Peugeot 406 2.1TD
Re: Aux Belt.
Have you got aircon? Did they check the alternator? Have you run the car without the aux belt to see if the noise disappears?gingerryno wrote:Hi, My peugeot was in the garage today and they did a fan belt replacement. they said that the tensioner didn't need replacing and they checked all of the other pulleys but they all seemed fine. i dont know if the problem will happen again but i am not to convinced that the problem has been resolved. does anyone else know what the ploblem may be?
Cheers
