406 Clutch and Gearbox
Posted: Fri Apr 24, 2009 6:56 pm
by Pob
Hi all,
Is there any difference between a Turbo and a 2.0 gearbox? I was wondering what difference's if any between the two regarding clutch plate/flywheel diameter.
Many Thanks,
Dan
Re: 406 Clutch and Gearbox
Posted: Sun Apr 26, 2009 12:44 am
by alladdin
Pob wrote:Hi all,
Many Thanks,
Dan
yes a 2.0 gearbox is much larger than a turbo. :lol:
sorry ive been drinking :P :P
Posted: Sun Apr 26, 2009 5:28 pm
by mjb
Gear ratios. Each box is geared to match the engine output, put the wrong box on and you'll kill the performance
Posted: Sun Apr 26, 2009 6:01 pm
by alladdin
ratios between petrol engines should be broadly similar. a turbo engine will produce much more tourque tho so might well be beefed up and have a larger stronger clutch. also since the diff is included with the box you have the overall gear ratio to consider. a 3.0 turbo will normally have a taller ratio than a 1.8
Posted: Sun Apr 26, 2009 7:06 pm
by mjb
alladdin wrote:ratios between petrol engines should be broadly similar
The 2.0 turbo is a low revver so the gears will be far too long for the non-turbo petrol 2.0
Posted: Sun Apr 26, 2009 7:57 pm
by Pob
Does the 2.0 gearbox/engine use the same size clutch plate and flywheel as a 2.0 turbo? The reason I'm asking is that I'm putting a turbo engine in a 205, people use a Mi flywheel and clutch so it fits a 205 gearbox. I was thinking of using a 406 gearbox so I can use the standard size clutch rather than a smaller Mi one as they tend to give up after a while. As I carn't use a turbo gearbox as its hydraulic, a 2.0 gearbox is cable so it should work.
Thanks,
Dan
Posted: Sun Apr 26, 2009 9:45 pm
by alladdin
you will probably find they are similar. the taller gearing is due to the diff ratio.
are the ratios in a haynes these days ? i doubt it.
as for clutch , look at the diameters, bigger is better. i have no idea which bits mix /match tho.
