HELP. suspected head gasket questions
Posted: Mon May 04, 2009 1:40 pm
hi everyone,
i have a 03 plate 110 hdi 406 that last year was blowing all the water out the filler cap of expansion bottle. had new head gasket skim timing belt etc £700 + pounds worth. wife hardly used car so sold second car and started using it myself only to discover same problem. been back to mechanic who claims not head gasket problem will either be head cracked or cylinder liner cracked.
my problem is when he stripped it there were 2 snapped head bolts and when i checked the reciept there are no new bolts on reciept he claims they came with head set but hes prices match the qoutes i got without head bolts.
my question is could there be something else causing similar symptoms ie thermostat fan not working properly temperature sensor. i ask this because occasionaly it will say engine overtemperature shortly after starting and the gauge drops to zero but when it bounces back the reading is normal.
any hints tips advice welcome as desperate to get car sorted spent a lot on it dont want to get ripped off any more. i am a maintanence engineer myself but it has been years since working on a car and they have changed a little everything being computer managed now.
thanks for any advice in advance.
rob
rob
