Page 1 of 2
Before and After
Posted: Sun May 24, 2009 10:17 pm
by poddack
On my search for a little problem with my 2.1td Executive estate, a flat spot between 3000 and 3500 rpm I thought I might take the fuel guage / pickup unit out of the tank and here is what I saw.........
Re: Before and After
Posted: Sun May 24, 2009 10:19 pm
by poddack
I think she's smoother but I'm not sure at the moment.
Posted: Mon May 25, 2009 12:30 am
by swiss
Ouch. Now I'm paranoid about my pick up... specially with all the chicken grease I've been putting in there lately O.O
Posted: Tue May 26, 2009 8:39 am
by mjb
Makes me want to rip mine out now
Posted: Tue May 26, 2009 9:53 am
by Daveyravey
Have you been running the car on old chip fat ?
Posted: Tue May 26, 2009 11:23 am
Wow! that is really bad
It looks kinda waxy/oily
Certainly would have affected the pick up rate I would say, but if not that's a good bit of maintenance to do anyway
Posted: Tue May 26, 2009 10:01 pm
by poddack
I bought her with the intent of running on veg oil, but the Lucas Pump is no good for that so only normal diesel.
Posted: Wed May 27, 2009 9:52 am
by mark21TD
poddack wrote:I bought her with the intent of running on veg oil, but the Lucas Pump is no good for that so only normal diesel.
Have you read the post about the 2.1 pump change, it needs updateing now as he's almost there.
With a Bosch pump it'll love veg oil.
Posted: Wed May 27, 2009 11:25 am
A 'P' reg 306 diesel passed me in the street the other day - followed by a strange smell of cooking
Posted: Thu May 28, 2009 9:09 pm
by poddack
I'm going to wait unit I get an old BMW with the M51 engine before I faff with veg oil again.
Posted: Fri May 29, 2009 9:05 am
poddack wrote:I'm going to wait unit I get an old BMW with the M51 engine before I faff with veg oil again.
Ooooo, I see, nice engine that but not
that economical on 'Diesel' I understand............
http://www.openhardware.de/mechatronics ... index.html
Posted: Sun May 31, 2009 6:25 pm
by Doggy
My bro's 306 1.9TD ground to a halt today with a similar problem.
We noticed the priming bulb collapsing due to vacuum, so limped it home & withdrew the strainer. This one was a LOT worse than poddacks, the gauze was completely invisible and the layer of gunbe was getting on for 1/4" thick
Easy job though, only about half an hour start to finish
Unsurprisingly, it goes a bit better now
Posted: Sun May 31, 2009 9:28 pm
by poddack
Fantastic, looks like a routine job to do when you buy one second hand.
Posted: Mon Aug 31, 2009 7:39 am
by BruceT
will my 2000 406 hdi90 have the pump filter and will it just lift out from under the seat?
Posted: Mon Aug 31, 2009 8:22 am
by mark21TD
Why wait for a BM when you have a bettor veg engine in the 406 !
All you need to do is get rid of that Lucas and install a nice Bosch pump then it will give you less problems than an M51engine (they mave isues with the intank pump and the VP37 / 36 injuction pumps blow seals when they get a bit older).
viewtopic.php?f=1&t=7281
BTW a build up of crud on the tank strainer is not uncomon on a diesel with a few miles on it.
