Clunk drivers side front....
Pob
Post by Pob »
Hi all,
Recently my 406 has started to make a clunk noise when you turn a corner that isn't perfectly flat.... It will only do it once and not all the time. You can feel it near the bulk head, well you can feel it through the accelerator pedal
Any Ideas?
Dan
Re: Clunk drivers side front....
It'll probably be the pear shaped rubber that screws into the OS wheel arch; the top engine mount bolts over the top of it.
It took me absolutely ages to track this down on mine, I changed the drop links, rollbar bushes and top engine mount and it was only when I changed the alternator and had it all apart that I noticed the rubber bush was loose :roll:
Pob
Post by Pob »
Thanks for the reply, I'll look into it and let you know :)
Thanks again,
Dan
Pob
Post by Pob »
I managed to get round to checking the mount while doing a cambelt change... You were right, it was loose and now the clunk noise is fixed! It was getting worse, I was beginning to think it was something a little more serious. Makes a change it being a simple fix
Thanks again,
Dan
No worries Dan, it took me ages to track it down!
