2.1td glow plug relay
Posted: Wed Jun 03, 2009 2:53 pm
Fellas,
I have owned my 1998 2.1td estate for 4 years and every 6 months or so it wont start 1st time.
If it winds over for more than 2 seconds then it aint gonna start, turn ignition off and it will fire up next crack straight away.
Last night it did exactly that,
This dinner time upon leaving work to go and get a sarnie it started on the 3rd go.
Upon trying to leave town to come back to work it started on the 6th go and on go's 3,4 and 5 the heater light was not showing on the dash, on go number 6 it was showing and it started.
(the previous times it has not started the heater light has been showing)
I got back to work and have just started it 6 times in a row 1st time.
I dont like it when your car 'sometimes' starts, its always in the back of your mind that its going to let you down.
I dont think its glow plugs,
where is the relay for the glow plugs - is it worth replacing this?
I can hear a couple of bits clicking when the heater light appears on the dash but i can hear nothing clicking when the heater light goes out. - is that normal?
Do the plugs stay on after the engine is running for a while? - reason i ask is that i turn the key until the heater light is on, then turn the key off and after approx 30 seconds i hear a couple of clicks from under the bonnet and i thought it may be a timer to de activate the plugs.
Any pointers or advice will be greatly received as i want to try and eliminate any intermittant starting issues.
