a couple of niggles
- welshviking
a couple of niggles
Hi, Only my 2nd post on here so be gentle with me. I have a 2002 406 hdi 110 executive it has 155k on the clock. The problems i have is when i 1st purchased it it was a poor starter if i would have paid more than the £1030 i paid for it i would have walked away from it, anyway i gave it a service oil, all filters new auxillary belt (snapped 2 days after i bought the car
)and a can of forte injection cleaner added straight to the fuel filter and the remainder of the forte to the fuel tank. It is starting better now but still not perfect, my wife owns a 2001 Picasso hdi and the 406 starts no where near as good as the Picasso. Any ideas what the starting problem maybe...(injectors, fuel pump etc etc ?????). The 2nd problem i have is when i put my ignition on i cannot see the oil pressure light lighting up, i realise there are no bulbs in the dash (learnt the hard way when went to replace it) so could it be the oil pressure sensor has been disconnected and if so where would i find it. Finally i can here a slight ticking when it first starts could that be a dodgy injectors ?....Thanks in advance...Colin
2002 D9 406 EXECUTIVE HDI 110 BHP SAT NAV, CRUISE CONTROL, HEATED LEATHER MEMORY SEATS ETC ETC
- Site Admin & Mad Biker!
Re: a couple of niggles
There could be a fault with the lift pump, have a search as there are quite a few posts on that.
The two main suspects are the low pressure fuel pump (lift pump) under the back seat and the glow plugs could be on the way out. Also, looks like your oil pressure sensor is malfuctioning.
- welshviking
Sorry forgot to mention the glow plug were checked and are fine, where is the oil pressure sensor located ? thanks Colineoin27 wrote:The two main suspects are the low pressure fuel pump (lift pump) under the back seat and the glow plugs could be on the way out. Also, looks like your oil pressure sensor is malfuctioning.
My money's on the LP pump in the fuel tank, also check the crankshaft pulley, the aux belt tensioner and idler for snapping belts. the crankshaft pulley sometimes comes loose off the crankshaft or splits into three (noisy when that happens).
Hmmmm, straight 6 goodness!
- welshviking
Thanks Guys....will look at this over the next few days as off to work now for a 12 hour night shift.....Cheers Colin
Come to think of it, my oil pressuree warning light doesn't come on eitherwelshviking wrote:The 2nd problem i have is when i put my ignition on i cannot see the oil pressure light lighting up, i realise there are no bulbs in the dash (learnt the hard way when went to replace it) so could it be the oil pressure sensor has been disconnected and if so where would i find it.
I noticed this when I changed the oil - now I'm wondering if this is normal?
Anyone with a later D9 HDi got an oil presure warning light that works?
I checked the manual - it shows the same dash layout for both petrol & diesel, so you can't be sure, (I'm fairly certain the particle filter blocked light won't work on a petrol for example)!
Manual's a tad misleading too as the technical spec lists a V6 16V - honestly
What oil pressure warning light?
My Parants 306 had problems starting and that was the fuel lift pump
I assume you listen for it when you turn the ignition on (with the backseats lifted)
Also i think the oil pressure sensor is screwed into the block under the fuel filter. You
can just see it throgh a small gap
Roger
Roger
Strange, when the lift pump decides to go on strike then the starter will spin over for ages with no joy but I'm thinking this guy's saying it's slow to start as in it always fires but takes a few revolutions of the starter each time as if he's having to coax the thing to life.
Mine used to go: wah wah wah wah wah.......Kalang alanga alanga
sorry, what I mean is it made like 5 revolutions or pulses of the starter motor each time whether hot or cold it was always the same.
Poor starting on a HDi can be down to low rail pressure (injection pressure) due to a worn HP pump. I'd be tempted to get to a garage you can trust with a recent up-to date diagnostic machine to read the live rail pressure or other stored faults (298bar at idle appears to be the benchmark of a HDi in fine order, rising to 600+ when revs increase etc.)
Mine sounds exactly the same! LOLWelly wrote: wah wah wah wah wah.......Kalang alanga alanga
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
Your car plays jazz to you?lofty wrote:Mine sounds exactly the same! LOLWelly wrote: wah wah wah wah wah.......Kalang alanga alanga
- welshviking
Thanks for all your advice guys, just been onto my mate who works in a breakers yard and they have a working fuel pump from a 2003 HDI 110 bhp which has been written off, the best part is I can take it away and try it to make sure that the pump is the problem. Obviously the next question is how easy is it to fit a pump and is there anything else I will need to purchase before fitting. I know you remove the rear seat and lift the black round inspection cover but then what ? Also regarding the oil pressure switch seems to be a few of you who have the same problem as myself with no light on the dash so the question is do the D9 actually have this function as i don't want to be crawling around underneath looking for something that actually does not exist....thanks for all your help on this matter it is very much appreciated and if I can sort these 2 problems out its just a case of a replacement front offside wheel arch liner and sort out the dreaded rust on front of the bonnet (seems to be a common fault with newer 406's which is amazing for a 7 year old car)....Regards and thanks ...Colin
Can you turn off your blue font please it sends your eyes funny.
There's a thread somewhere showing a link to a tool you need to get the ring off the fuel pump but you should listen for this pump to see if it sounds 'grumbly' when you put the key to ignition. If it sounds horrible and grumbles then it's knackered. Also the black inspection cover was rivetted on mine (not sure how the garage got it off but drilling out rivets near the top of a plastic tank......you know).
I'm sure my 1999 HDi had the traditional 'oil can' warning but I'm wondering if the later models just show the 'STOP' light?
- welshviking
Welly wrote:Can you turn off your blue font please it sends your eyes funny.
Thanks for the reply...Firstly font now Black....secondly i will have a good listen to the pump shortly but if i remember it does not sound too healthy , i will look on here for the link to the tool needed i actually asked 2 mates who both have later model 406 and neither of them had a oil pressure light, now either theres none on the d9 models of a whole lot of dodgy sensors
