jasper5 wrote:Why are you looking for a new head?
If you only had a cambelt failure it's fairly certain that the head can be reconditioned.You may be lucky and only bent a few valves.
Do you have a local engine reconditioning place? If so, price up a recon job.
I did look at this option but due to the valves being longer all be it the same diameter etc, etc the valves are very expensive as they are an odd ball size (length) due to the fact you can always cut a bit of but not so easy to put a bit on, also it's needing all valves due to the fact if one spring breaks you replace the pair.?
I usually do, also i suppose everything comes down to cost and "where do you stop"
not 1 had the head with the EGR valve at the back of the head...
In my local area there was 17 406 Petrol's being broken I already have a credit note for a head i had picked up as i was assured it was the correct one, no cash back from the breakers as we all know....shower o shite that mob..
