Tensioner sprung or manual ?
Posted: Wed Jun 10, 2009 9:36 pm
Hello
A friend of mine has a March 1999 1.8 petrol 406, engine type XU7JP4. We are going to change the timing belt, but I have a few questions. Apologies if you have been over this stuff many times before.
1. We will replace the belt, tensioner, and idler pulley, but is there anything else that’s essential? I want to keep the total cost down, but don’t want to miss anything important. The car has done about 140,000 miles.
2. The Haynes manual (number 3394) is not very clear about how to tension the belt. It gives 2 methods.
a) The recommended method is using a special Peugeot gauge to check the tension, obviously I don't have that.
b) The other method involves setting the tensioner by hand and feeling the tension required to twist the belt the through 45 degrees. This doesn't seem very robust at all.
However when I went to my local car parts shop they offered 2 kits, one with a manual tensioner and one with an “automatic” tensioner. I guess the automatic one is the sprung type, with an indicator so it is clear that you have the right tension. I have used these on a Ford (same as Peugeot HDI) before. Does anybody know if the automatic tensioner will fit if a manual one is currently fitted.
Any advice will be gratefully received
Conor
Conor
