406 D8 Diesel 2.0 - Wont start when hot
Posted: Sat Jul 25, 2009 5:36 pm
by pugSL
Hi,
I own a 406 D8 diesel. Its the 2.0 liter model. I know usually diesels tend to be hard to start when the engine is cold but my problem is totally the other way around.
It starts when I crank it for 2 3 seconds when cold (after pre heating of course) but when the engine is hot it either starts after a cranking for about 7-10 seconds or simply refuse to start....
Of course every thing gets back to normal when the engine cools down....
Anyway after starting it runs without a problem (idle at a steady 900-1000rpm). Though sometimes i feel there's very little power from 1000-2000rpm Sad
Has any one else experience similar problems????
Confused Help please
Re: 406 D8 Diesel 2.0 - Wont start when hot
Posted: Mon Jul 27, 2009 4:50 am
by pugSL
Hi guys,
I removed the diesel filter and cleaned and refixed the filter. There was some dirt in trapped in the filter. Probably from the tank. The car was sitting for a long time i guess..... Anyway this didnt fix the problem....still wont start when the engine temp is above 80degrees..
Last night some thing strange happened....I switched off the engine took out the ignition key and went inside my home. Then i came back to the car after few minutes, only to find that the radiator cooling fans are working....
Everything was turned off and the ignition key was in my hands
Whats going on guys...I'm thinking the temperature sensor or the cooling fan control unit (if there is such a thing) is giving trouble?? Please help
Posted: Thu Jul 30, 2009 4:52 pm
by pugSL
Hi guys,
I noticed that the hand pump for the diesel bleeding process is sort of squashed.
see the attached photo... I couldn't find any leaks or anything...Whats the reason for this??? I thought maybe the fuel supply line was blocked. But it didn't take the right shape when i removed the pipe from the filter end.
Posted: Thu Jul 30, 2009 10:13 pm
by Doggy
I suspect you've got a blocked strainer in your fuel tank - see
this thread
Could also be a partial blockage in the fuel line / squashed pipe or similar.
Yours looks like a 1.9TD BTW - (this could have confused the issue a little and might be why no-one responded sooner).
Welcome to the forum
Posted: Mon Aug 03, 2009 4:35 pm
by pugSL
Hey thanks for the info....can you point me as to how to remove the fuel gauge/pick up unit from the fuel tank...I had a feeling there might be a blockage because the hand pump collapsed. Also the the fuel gauge is give strange readings...some times it actually shows an increase in fuel
BTW i removed and cleaned the fuel filter as well (couldn't buy one over the weekend
) there was lot of dirt inside. i've attached a pic how it looked inside
Posted: Fri Aug 07, 2009 5:26 pm
by swiss
Pick up a Haynes manual, pretty common on Ebay and handy for these kinds of jobs.
Short answer is you have to whip out the back seat. Pick up is on the driver's side IIRC. The 1.9 doesn't have a pump in the tank so all you should have to extract is the level sender and pick up bits.
Posted: Sat Aug 08, 2009 6:10 pm
by pugSL
Thanks guys will try that and see
