Torx bolts, front caliper
Posted: Mon Aug 03, 2009 9:27 pm
by elmtreeandy
Can someone please tell me the size of the torx bolts on the front caliper? 1998 2.0 hdi. Thank you in advance, Andrew
Re: Torx bolts, front caliper
Posted: Mon Aug 03, 2009 11:22 pm
by ger
On the v6's with the Brembos the bolts are Tx55 and are tightened to 120Nm (or 90lb.ft), with some threadlock for good measure.
I can't imagine them being different on the other models.
Posted: Tue Aug 04, 2009 6:50 am
by elmtreeandy
Thanks for that. My range goes to T50 and I knew it was bigger but not sure whether it was T55 or T60.
Posted: Tue Aug 04, 2009 12:38 pm
by teamster1975
ger wrote:tightened to 120Nm (or 90lb.ft), with some threadlock for good measure.
And pigs to undo!!!!
Posted: Tue Aug 04, 2009 8:09 pm
by mjb
teamster1975 wrote:And pigs to undo!!!!
Unlike which other screws/bolts on the car? :lol:
Posted: Tue Aug 04, 2009 9:52 pm
by adam03031980
Mine were as tight as anything but found that trying to do it up a little first then undo it helps
Posted: Tue Aug 04, 2009 11:25 pm
by Mountain
Yep, a little whack often does the trick!
Peugeot and torque bolts :shock:
Posted: Mon Aug 17, 2009 12:36 am
by Arcangel
T 55
Plus a good soaking with Wurth 'Rost-Off Ice' use it with work, good stuff
