Problem starting in the morning
Posted: Sun Aug 09, 2009 5:51 am
Hi
It takes 8-10 turns of the key to start in the morning. Once I start it and turn the engine off there's no problem restarting it. Just first thing in the morning. The longer I leave it with the engine off, the harder it is to re-start. If I leave it for 4 hours it takes about 3 turns of the key to start. Overnight 8-10 turns. It's as if the fuel isn't getting into the engine
When I try to start it and I put my foot on the accelerator, this doesn't help either. In fact putting the foot on the accelerator feels as if it extinguishes the starting process.
Also, when I am trying to start it, for a second or 2 after I turn the key the engine chugs for a bit (it doesn't sound healthy) with the rpm way below what it should be.
I hope my explanation helps! Thanks
