just bought a d8 2.1 diesel and i think this car would benifit from a cruise control,done a quick search and find that they are fitted to some hdi so
can i retro fit one to mine?
cruise control
Re: cruise control
Yes, but not one from an HDi obviously. My 2.1 even seems to have all the wiring already.
Re: cruise control
I thought I'd save you some ag and look on Service Box but it looks like they never fitted it to diesels (
). There's plenty of bolt-on goodie ones on evilbay tho.
Re: cruise control
aha - that explains a lot.steve_earwig wrote:I thought I'd save you some ag and look on Service Box but it looks like they never fitted it to diesels (). There's plenty of bolt-on goodie ones on evilbay tho.
always wondered why all listings to the executive said it came with cruise control, and yet for some reason my 2.1 exec didn't have it, now i know
1997 2.1TD executive estate - mmmm, lovely
Re: cruise control
Only Hdi's from around 2000/2001 on. (works by ECU holding the engine RPM, unlike petrols with the servo mechanism to work the throttle).
Re: cruise control
D9 (2001-) petrols with cruise work via the ECU too, as they're drive-by-wire and the throttle cable's not attached to the throttle body. I don't know of any pre-2001 petrols other than the V6 which had cruise control, and then the V6 works by a vacuum pump pulling on the throttle at the same place the cable's attached to...dogslife wrote:Only Hdi's from around 2000/2001 on. (works by ECU holding the engine RPM, unlike petrols with the servo mechanism to work the throttle).
Re: cruise control
My D8 2.0 petrol Executive Auto has cruise control, it was fitted on some D8 GLXs and all Exec autos. Very useful it is to...
Re: cruise control
hi thanks for all the replies but i think fitting one is no no from what ive read now
