Cruise Control
Posted: Wed Sep 02, 2009 9:57 pm
by welshviking
Hi, Not posted for a while cause had no problems with my 406 that is until the last few days (especially tonight). Doing 70mph with the cruise control set and all of a sudden the cruise control cut out (did not touch the break or clutch pedal) i now cannot get it to come back on. It did the same thing a few days ago but the next time i went in the car everything was back working ok. Is there any common fault i should look for tomorrow , any advice or help would be very much appreciated...Regards Colin
The 406 is a 2002 executive saloon.
Re: Cruise Control
Posted: Wed Sep 02, 2009 10:30 pm
by mjb
1. Check the fuse (don't ask me which one...)
2. Try pulling the clutch and brake pedals up with your foot
Re: Cruise Control
Posted: Wed Sep 02, 2009 11:35 pm
by Doggy
Mine has done something similar a few times and always been OK the next day
I've yet to find the problem, but mine usually refuses to turn on, never had it drop out.
Made my mind up to check the pedal swithces last time, but it started working before I got the chance.
Re: Cruise Control
Posted: Thu Sep 03, 2009 9:00 am
by welshviking
Thanks guys for your help, will check both pedal switches today after i have checked the fuse...(if i can find the damn thing
).....Regards Colin
Re: Cruise Control
Posted: Thu Sep 03, 2009 9:16 am
by DaiRees
Re: Cruise Control
Posted: Thu Sep 03, 2009 11:44 am
by welshviking
Tell you what Dai you may have a point as the only times it has cut out the auto lights have been activated.....i will have a look at the rear bulbs as well....Cheers Colin
Re: Cruise Control
Posted: Fri Sep 04, 2009 8:19 am
by welshviking
Well i sprayed both pedal switches with switch cleaner and managed to spray inside the cruise control switch and went on a 25 mile journey to the hospital to see my mother last night...no problems at all..worked 100%....However on my return journey i set of then the auto lights came on and the cruise control once again dropped out. So what i did next was to switch my auto lights feature off ( just incase there is a problem with the auto lights affecting the cruise ) and tried just normal lighting and again the cruise control would not work...so Dai's reply might be very close to the problem..i will check and replace any bulbs today and let you know the results later...Cheers Colin
Re: Cruise Control
Posted: Fri Sep 04, 2009 12:16 pm
by welshviking
SORTED !!!!
Found the fault to be when i put my lights on the high level brake light also came on.The brake lights were all working as they should when the lights were off but the high level staying on when lights are on.In the end and it took about 1 hour traced fault to my towbar socket, simply one of the female pins had pushed in too far and was making the high level brake light operate with the lights, i managed to pull the pin out to where it should be and it was sorted.....Cheers for all your help Regards Colin
Re: Cruise Control
Posted: Fri Sep 04, 2009 12:51 pm
by DaiRees
Good news fella
Re: Cruise Control
Posted: Fri Sep 04, 2009 1:00 pm
by Doggy
Well done Colin
(& thanks too to Dai).
I shudder to think how much that might have cost if you'd let Pernod's finest loose on it!
Thinks, I've got a towbar too......
Re: Cruise Control
Posted: Fri Sep 04, 2009 1:08 pm
You gotta love a cheap fix like this.
Excellent work.
Re: Cruise Control
Posted: Fri Sep 04, 2009 1:24 pm
by welshviking
Welly wrote:You gotta love a cheap fix like this.
Excellent work.
Its a bonus not having to spend any money to fix it and i can now use my cruise control at night
