play in rear bushes..
Posted: Thu Sep 03, 2009 7:54 pm
by jbh325i
well been under the rear of the 406 as i noticed its wearing tyres on the outside edge. I've took a pic and there's play in the rear bush on the bottom of the hub carrier I've outlined the bolt where i can see the play..
1. are these an expensive repair
2. whats involved in doing this is there any other bushes i should replace while im in there
3. what part am i asking for when i go to get them
heres the pic of the offending bush
Re: play in rear bushes..
Posted: Thu Sep 03, 2009 9:05 pm
by jasper5
Are you sure it isn't the top bushes? These are the most common to fail.......
viewtopic.php?f=10&t=7376
These worn bushes cause wear on the rear tyres.
Posted: Thu Sep 03, 2009 9:20 pm
by jbh325i
jasper5 wrote:Are you sure it isn't the top bushes? These are the most common to fail.......
ill double check tomorrow in the daylight but i definitely saw movement in the one I've marked on both sides. i could hold the wheel at the bottom and top and move the hub assembly. my tyres are wearing on the outside if that makes a difference ..
Posted: Thu Sep 17, 2009 12:07 pm
by jbh325i
ive had it in for an mot and its failed on the bushes ive marked so looks like i was correct. the fail slip states offside/ near side lower axle swivel joints has exessive play so has any one done these ? do i need a puller? any one got the part number for them ?
Posted: Thu Sep 17, 2009 3:07 pm
by HimBigChief
I had to get one done for my MOT last year. I took the hub off and took it down to the local garage along with the bush (about £20 IIRC for the bush) and the garage pushed out the old one and pressed in the new one for me. Put it back on the car and passed fine.
Part numbers are either 3640.35 (£32.02 inc VAT) for models upto production number 07664 and 3640.41 (£23.95 inc VAT) for models after 07665. Prices are Peugeot prices, but you can get the same bushes from GSF, ECP, etc.
Posted: Wed Oct 07, 2009 10:23 pm
by jbh325i
just gotmy uncles garage to do the work for me so thats them done so fingers crossed they shouldnt n eed done again while wee have the car..
next on my to do list is get a bonnet as its badly rotten along the front
