Hi, I dont know if this is in the right section, so if its not, im sorry mods.
Basically, had to call the AA out today to start my 406. Guy came and told me i had a dodgy earth from battery to gearbox, and a 'lazy' starter motor. Have replaced the earth cable. Thing is, the starter is very tempermental. It started on the key a few times this afternoon, however, tonight when taking kids to a halloween party, i turned the key and it was dead. I had to tap the motor with a screwdriver, and then it started.
So question is, do i need a new starter motor, or would a clean/grease do the job?
Also, is the tubby motor specific to the model, or would a 2.0 16v / 1.8 16v jobbie do the trick???
Tubby Starter motor
Tubby Starter motor
406 TURBO
Lowered 80mm
13psi Boost
Bailey Dump Valve
Full Powerflow Stainless System
Induction Kit
good bye MR2's!
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
Re: Tubby Starter motor
not sure bout the 2.0 and 1.8 starter probably is the same but with ref to your starter id take it off strip it down and clean the brushes if you dont fancy doing it get it to a local auto electrician theyll do a full refurb for you
406 3.0 V6 saloon
- DaiRees
- Site Admin
Solenoid? Can you hear it clicking when you turn the key or there no noise at all?
As nigel says, you should be able to get it refurbished for a fraction of the cost of a new one.
with the above, you could also get one from a scrap yard. easy to get to anyway so shouldnt be a problem but its definately the solenoid
Thanks guys. Is the solenoid attached to the starter motor then? Im going to the scrap yard later today.
406 TURBO
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
- HimBigChief
Yes it's attached. It's the smaller of the two cylinders, the larger is the motor itself. You'll see what I mean when you get your spare one from the scrappy.
