Turbo seals//turbo help
Posted: Fri Nov 27, 2009 6:01 pm
by LowRiding406
Hi,ive got a 110 hdi mk2 406 wound the actuator right out to gain more boost its great but finally 6 months later the seals have blow on the turbo does any 1 know wher ei can get any cheap seals from or turbo and what bigger turbos will fit can sum1 aid me in the right direction i have a mobile if sum1 could ring me or text me sum information on what turbo is on my hdi 110 what (t) it is and what bigger turbos i can fit as i have a fmic ready to fit (front.mount intercooler) please feel free to contact me on 07907 375298 (simon)
(1 off 406 possibly the lowest in the u.k with 20mm ground clearence)
Re: Turbo seals//turbo help
Posted: Fri Nov 27, 2009 8:26 pm
by TopDonkey
I am no help with the turbo seals i'm afraid, but i'm curious about how you got more boost, the 110 HDI engine is electronically controlled with feedback from the boost presure sensor, so no matter where the actuator rod is set, it will still only give you 1 bar of boost, Or have you done other mods to get more boost ?
Posted: Sat Nov 28, 2009 10:30 am
by LowRiding406
yes that is right it is running 150bhp instead of the standard 110, the down fall is it that from 2nd in high revs to 3rd engine management light cuts in n stops the power dead also does this in 3 and 4th at 3000rpm but in 5th it boosts upto 3000rpm (90mph) then after the turbo boosts for 3-4 seconds then cuts out for 2-3 seconds then carries on again keep doing the same thats when i blew the turbo when i went off the clock ,,,its a right b***stard thats why im looking for a bigger turbo so that the engine management light wont cut in when its been chipped and re-mapped(live re map is reccomended) the turbo spools up majorly now jsut changing the back box to straight pipe with a fancy attachment the sound it gives is great lol(sounds like a jet plane going by lol) but hopefully if i can get a bigger turbo i can get it pushing 250 after chip and map
Posted: Sat Nov 28, 2009 2:21 pm
by londoner1
Hi,
My turbo went a few months ago, got a recon one from eurocarparts and now the car is ok. To determine turbo type you need to look at the log book and teh vin/chassis number, mine had RHZ in it and after googling, it brought up the correct turbo number : DW10ATED/RHZ
Hope that helps.
Posted: Sat Nov 28, 2009 5:33 pm
by LowRiding406
ah nice one pal peugeot give me the part number for myn is 37594 KKK (no im not being raicst ) that is the actual part number so if any 1 is breaking a 406 and got that turbo let me know please asap and how much was your turbo from euro car parts (im fuming cuz only broke a 110 hdi up the other month but didnt have time to get the engine out >.<
Posted: Sun Nov 29, 2009 1:51 pm
by londoner1
hI,
£365 INC VAT.
Posted: Mon Nov 30, 2009 5:52 pm
by LowRiding406
is that for my turbo and were from euro car parts?? i can get myn reconned for 50 quid but tis getting the seals for it any idea were i can get hte oil seals from???
Posted: Wed Dec 02, 2009 12:36 pm
by mjcook1984
ebay would be ur best bet there plently of turbo rebuild kits on there
Posted: Wed Dec 02, 2009 4:30 pm
by LowRiding406
yeah been looking tar its just getting the right seal kit there is a place local to me that can make seals/ gaskets to order / fit for anything its just a case of if there is anything left of my oil seals lol
