clutch 406 2.0i 98 r reg
Posted: Thu Dec 31, 2009 4:45 pm
by fergy
hi all im having problems.....i need a new clutch as the thurst bearing is sticking only in 3rd and 4th i have repaced the cable a few month ago and it went away now its back..... anyone got an idea of the cost of fitting a clutch is?
Re: clutch 406 2.0i 98 r reg
Posted: Tue Jan 05, 2010 9:50 am
by fergy
thanks for help not!!!!! n its £350 plus vat should of got a vectra not this crap 406
Posted: Tue Jan 05, 2010 7:45 pm
by teamster1975
Hey take it easy! We've all been busy around the new year!
£350 is a pretty good price for the clutch, how long have you had the car?
Any other problems as you don't seem to rate it that highly?!
Posted: Tue Jan 05, 2010 7:59 pm
by DaiRees
If you think a 406 is crap you've obviously never tried a vectra
Good post Matt, very restrained
Posted: Tue Jan 05, 2010 9:04 pm
by teamster1975
DaiRees wrote:Good post Matt, very restrained
You know me Dai, I'm very mellow until someone pisses me off!
Posted: Wed Jan 06, 2010 10:58 am
by fergy
had a few other problems with it hand brake works when it wants and there is some thing lose some where on driver front side cant find what is doin it and it only happens between 2000 to 3000 revs,and sorry about my reply before just the car is stressing me out, also the cam belt its done 121000 miles and it was changed at 71000 about 3years ago and not sure when it need redoing the car has good main dealer service history been well looked.
Posted: Wed Jan 06, 2010 11:54 am
by robb
They do say patience is a virtue
Posted: Wed Jan 06, 2010 2:28 pm
by teamster1975
fergy wrote:had a few other problems with it hand brake works when it wants and there is some thing lose some where on driver front side cant find what is doin it and it only happens between 2000 to 3000 revs,and sorry about my reply before just the car is stressing me out, also the cam belt its done 121000 miles and it was changed at 71000 about 3years ago and not sure when it need redoing the car has good main dealer service history been well looked.
These things are sent to try us at the best of times!
If you've got a knocking from the front O/S it'll be either:
Antirollbar bushes/droplinks
Top engine mount
I had the same problem, replaced all of the above and it turned out to be the pear shapped rubber mount that screws into the wheel arch that the mount bolts on to. Basically it was loose; you have to remove the top mount to tighten it up but it's an easy job.
Re the handbrake; jack up the back and take the wheels off; you'll see a rubber plug in each disc (or not if they've been lost!!).
When you turn the disc to a certain point you'll see the teeth of a gear (a torch helps!); this is the shoe adjuster. With the handbrake released tighten this as far as it will go then back it off about 4 clicks, until you can turn the disc freely. Same on the other side.If the cable has never been replaced the cable adjuster will be rusted solid and you'll have to change the cables.
Check the condition of the antirollbar bushes while you're there as these will most likely be fecked, fairly easy DIY job as well. Also check for any play in the wheel while it's jacked up; the top links and antirollbar links are fairly common failure points which will cause play in the wheel.
Hope this helps, there are loads of threads regarding the handbrake!
