REAR BRAKE CALIPER
REAR BRAKE CALIPER
Hi All
I'm going to clean up one of the rear brake calipers on my 406 hdi (ate type) the sliders are a bit seized move a bit but not as much as they should. Once ive cleaned it all up what type of grease do you use on the sliders themselves? I have an idea that its like a cv grease (lithium based) but i just wanted to double check. Any advice would be appreciated.
Marco
Marco
- Site Admin & Mad Biker!
Re: REAR BRAKE CALIPER
I've always used copper slip on the sliders, I'm sure other peeps will chime in!
I use copper grease on brakes - it's designed for very high temperature use
The white lithium grease does the trick if that's all you got but I think all of us will favour copper-based as that one can go on the pads without fear of ending up on the disk.
in the garage we use copper slip or known on the tin as copper grease
406 3.0 V6 saloon
Thnks for the advice. One more thing. Whats the best thing to clean the sliders up with? I was thinking a bit of meths would be okay?
Marco
Marco
Wire brush/wire wool and WD40 usually, depending on how scabby they are!marco2002 wrote:Thnks for the advice. One more thing. Whats the best thing to clean the sliders up with? I was thinking a bit of meths would be okay?
Marco
I cleaned up the rear caliper and it wasn't sliding at all! Gave it a good clean with the wire brush and used copperslip on the sliders works a treat now. Quite happy with the result.
Only problem is after a week of driving about i've got a sqeeling noise on the back brakes only occurs when you put the car in reverse and back up a slight hill then put the brakes on. When i cleaned it all up i spun the discs a few times just to make sure the backplates weren't rubbing as usual and gave everything a really good clean up and used copperslip on backs of pads as usual......
Maybe i'll have to bite the bullet and take the pins & pads out and try re-positioning them. What a nuisance. Anyone else ever have anything like this before. If i didn't mention it already its a 406 hdi 110 GTX, discs and pads on the back....
Marco
Marco
Take out the pads and file a small chamfer on the edge of the pad material faces, then clean up the pad faces with some rough sandpaper.
Don't breathe in the dust from sanding.
Thanks Jasper
I'll give that a go tommorow (weather permitting been raining here non stop all day....)
Marco
Marco
Thanks for the advice Jasper. Did exactly what you said and the noise has gone!
One more question my the pads don't have any shims with them. Are they neccessary?
I'm thinking the garage may have removed them when the discs and pads were fitted.
Thanks Marco
Thanks Marco
Glad you fixed the noise
Shims are not always fitted these days, many cars don't have them.
Nice tip there Jasper, thanks!
I've got an occasional squeak from the front brakes since I replaced the disks and pads, I'll do as you suggested!
