how do i replace the front anti rollbar bushes
dragonslayer
Post by dragonslayer »
hi guys how do i replace the fron anti roll bar bushes on the d8 2 litre petrol.i havent a clue as i have never done these
many thanks in advance
dave
Re: how do i replace the front anti rollbar bushes
Front end in the air, put it on axle stands. Take the wheels and wheelarch liners off. You should be able to get at them now (just one nut+bolt, you'll need to stop one side from spinning while you turn the other). Then you've freed up the metal clip which you can take off. The bushes will now pull off.
Seeing as you're changing the bushes I would replace the drop links as well Dave!
dragonslayer
the drop links are new
dave
dragonslayer wrote:the drop links are new
dave
Don't replace them then!
