Some newbie advice on 1.9td
Posted: Mon Feb 08, 2010 2:21 pm
Hello all
I came across this site whilst researching 406's on t'internet, thought I'd join up and get some advice.
I went to look at a 1996 406 1.9td today-it was advertised as having a head gasket away hence very cheap. I checked it out and the coolant level was down(with no signs of emulsion) and the oil level was OK, again with no mayo. The owner says he could see water coming out of the exhaust and this is what made him think head gasket. He's bought a new car so no longer needs it.
It started(after a while) and ran and sounded fine. A wee bit of smoke on startup but none after that. The radiator looks past its best but there was no sign of any coolant leaks. Left it running for 10 minutes with no issues, I didn't want to run it any longer as it would need bled and couldn't drive it as no tax on it.
I've just done a head gasket on a petrol Mondeo which wasn't a bad job so I was ready to take this on but I'm not entirely sure the head gasket is away. Can anyone offer any advice as to other possible causes?
I'll look forward to any advice anyone can offer-the rest of the car is OK but not great-paint is a bit flat and the car is damp-I realise this is common-nothing that would put me off tho-to put it in perspective,the car has a fresh MOT and 4 good tyres, and it's £200.
Finally, am I right in saying its a Bosch pump on these? I would like to be able to use Veg oil in it...
Thaks in advance
Brian
Thaks in advance
Brian
