Rev counter
Posted: Mon Feb 08, 2010 6:21 pm
by redfar
Hello,
I have a Peugeot 406 1.9td and rev counter some times it drops to zero.I have read that there is a pick up sensor on the fly wheel but I can't find it.If some one knows the location exactly or can take a picture I will epriciate very much.
Re: Rev counter
Posted: Mon Feb 08, 2010 8:48 pm
by mjb
If the sensor's shot, the ECU won't inject any fuel so the engine will stop.
Your problem's more likely than not a dry solder joint on the back of the instrument cluster
Re: Rev counter
Posted: Tue Feb 09, 2010 4:33 pm
by redfar
I noticed today that when the car is on engine brake the revcounter drops to zero that's why I think it's a sender fault.When it's driving normally or on idle the rev counter does not drop to zero.
Re: Rev counter
Posted: Tue Mar 02, 2010 6:39 pm
by redfar
Problem solved it was the Crank Sensor mounted on the top of the gearbox.
Re: Rev counter
Posted: Tue Mar 02, 2010 6:50 pm
by mrcarlxx
redfar wrote:Problem solved it was the Crank Sensor mounted on the top of the gearbox.
the crank sensor on most cars are located on the block itself not the gearbox?
Re: Rev counter
Posted: Tue Mar 02, 2010 7:00 pm
Probably the bell housing, counting the starter ring teeth.
Re: Rev counter
Posted: Tue Mar 02, 2010 8:32 pm
by maglite1
ide second mjb on the crank scensornot being the problem as i had an astra cdti and when the crank scensor went the engine wont start , where as on my pug the speedo needle drops to zero and has a mind of its own at times , whack the dash and it comes back to normal , just being a lazy sod and not got round to removing clocks to re solder and clean as nesacery
Re: Rev counter
Posted: Wed Mar 03, 2010 6:57 pm
by redfar
Yes it's located on the bellhousing sorry not gearbox
Re: Rev counter
Posted: Wed Mar 03, 2010 9:45 pm
by mjb
It's mounted on the engine block, right next to the bell housing. It's on the top but towards the rear. Take the air filter box out and you should see it. See my V6 clutch howto for its location on mine...
